Drag hardware is all in
Very nice set up!!!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
chawkins what track are you going to and when? im only about 3.5 hrs from atl and steele al. track lays down vht by the bucket!!
when i go i usually drive down fri afternoon and grab a room about 2 exits north of steele in gadsden al. rooms are decent cheap and i can race till they run me off and go to bed drive home sat
I might even throw the Crossie on the strip and make a few runs for some comedic relief.
Should be good for low 14's or a 13.99X if the driver (me) is worth a crap.
I'm a twisty road guy, but Steve has tought me a thing or two about the 1320.
