Random CEL help!!! E55 Guys LOOK INSIDE
1st senario the first time It happeded was around last November when I got it. I took it to Advanced auto pulled the codes and it was multiple cylinder misfire. Cleared the code fired it up problem solved. I decided to replace all the Plugs with one step colder NGKs.
2nd Senario same thing cleared the code came on about 2 months after I replaced the plugs, Restarted issue gone.
3rd Senario Tonight Cel came on the way home from work, Started to run rough, CEL flashed for a few times then went solid. Pulled over and scanned codes p3005 p3006 p3007 p3008..... Cleared Fired up and came right back on. Cleared again and ran for a minuite and came back on.
Whats going on here guys?...........
Do you have access to a STAR system? That can probably diagnose the issue...I just hate paying for it every time I need something diagnosed.
Just don't get why it's not constant?????
You driving in rain or wash her today? Just curious. Mine freaks and throws misfires then too.
Like I said, it would probably save you a lot of time and frustration to bite the bullet and let someone w/ STAR look at it.
This poor guy spent 4500$ to figure out it was clogged cat causing misfires. Least the cat was covered under warranty.
I forgot though. I have floored fab heads like you BUT 100 cel race cats. Aren't you cat-less?
If so DAYUM! I would have thought we might be onto something.
Here's the post from the other guy
http://www.obd-codes.com/p0300
http://www.obd-codes.com/p0305
http://www.obd-codes.com/p0308
I know that Pullejo had some CEL issues after he installed the Floored Fab Longtubes, send him a pm as he got it sorted out. He also has a Eurocharged tune so maybe Jerry adjusted the some mapping.
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
A code P0305 may mean that one or more of the following has happened:
- Faulty spark plug or wire
- Faulty coil (pack)
- Faulty oxygen sensor(s)
- Faulty fuel injector
- Burned exhaust valve
- Faulty catalytic converter(s)
- Running out of fuel
- Poor compression
- Defective computer
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Seems like several people that installed FF LT's have had misfire CELs. I changed my plugs as well and that didn't fix it. I've spent ~$1000 diagnosing the problem, changing the plugs, labor, etc. and I still have the heater CEL on. I constatnly look at the solid CEL and wait for it to start blinking again.
How strange.
