Help with wheel spacer sizes
1 Post
2009 Cadillac CTS-V
I won in an auction a set of Vossen CV2's. They were taken off a 2010 E-class so they have a different offset than what I need on the 2004 E55. What I bought:
Front: 20 x 8.5 @ 44 offset
Rear: 20 x 10 @ 55 offset
I'm told the proper wheels would be .5" wider, with offsets of 32 and 42, respectively. So I was hoping to just put on some spacers. Two questions...
1. Would 12mm spacers all around be fine?
2. Does the front axel support hub centric?
I heard that the 2004 may need to be flat, without the flange. The rears are hub centric but that the fronts may not.
Thanks in advance!
Thanks in advance!
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
if you need spacers I may have a 4 H&R 15mm hub centric spacers. they are brand new.
on the front hub the lip is big enough to accomodate a 12mm spacers without a lip. on the rear hub you will need a hub centric spacers.
BTW i also live in the Stafford/ SL area
1 Post
2009 Cadillac CTS-V
I'm worried that 15mm maynot clear the calipers, no?
So you're saying I need flat spacers (not hub centric) up front?
Nice to meet you! Yeah, there's a few users in the greater Houston area I see. Cool!
bamaster I sent you some info in e-mail ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
We also have Akata wheels spacers, here is the contact info for your questions, thanks!
- Hub Centric
- High Grade Aluminum
- Multiple applications available for all makes!
Contact: akataspacer@gmail.com
305.877.3927
- Hub Centric
305.877.3927
![](http://farm5.static.flickr.com/4112/4954402703_6f30813384_b.jpg)
Thanks in advance!
Thanks in advance!
-Craig
