Any Solution For Broken Coil Harness Clips?
Hey Gang - A few of my harness clips on some of my coils have broken (they are so delicate \ brittle). I followed the harness but it is buried deep and tied into other harnesses. Luckily the plug is a tight friction on the coil itself, so there is minimal chance of the plug coming loose. Any thoughts?
Thanks!
Thanks!
1990 300ce supercharged and intercooled
You can buy replacement connectors and you need a special tool to remove the pins. Honestly most of the time we just zip tie them to the coils. I hardly ever unplug a coil any more though just for this reason.
Do you have a link handy on the tool? Thanks for the response.
I do not. I actually use something that I custom made because I got tired of buying the pin removal tools from Mercedes. They are very expensive and half the time do not work or I loose them. If you go to the dealership and ask to see one I am sure they would show you. Get the part number and order it up.
Ok thanks! I am very open to making or fabricating something that works better than the factory tool as well, so will also look into that, thanks for the heads-up.
