82mm TB bucking issue
Subscribe
Nov 20, 2014 | 12:01 PM
  #51
What mode are you all in when this issue occurs? Sport, comfort, or manual?
Reply 0
Nov 20, 2014 | 12:18 PM
  #52
Quote: What mode are you all in when this issue occurs? Sport, comfort, or manual?
I drive my car as dd, so it was in comfort
Reply 0
Nov 20, 2014 | 12:36 PM
  #53
Quote: I drive my car as dd, so it was in comfort
Have you tried to replicate the issue in manual mode?
To confirm, we are talking about a situation where the car rocks you back and forth several times before it settles and moves along and not the supercharger clutch engagement, correct?
Reply 0
Nov 20, 2014 | 01:39 PM
  #54
I am thinking the tunes tend to close that valve a lot more than the stock tune. I did notice that when I let off the gas after flooring it, the car certainly jerks forward after tune than before. I wonder how much of that is there at low levels when the threshold to open the valve is raised on tunes
Reply 0
Nov 20, 2014 | 05:24 PM
  #55
raised to the maximum idle in p and drive. came up to 2.0%, but jumps back to 1.2. CEL came back once again. I think something is in the tune
Reply 0
Nov 20, 2014 | 05:27 PM
  #56
I was about to post that, raising the idle with temporaly fix it, the ecu will adjust again. Before trying a new tune, can you swap the tb and connector with someone else that has it working?
Reply 0
Nov 21, 2014 | 12:35 PM
  #57
will be trying it next week, but with oe tune it didn't have cel for 400 miles, 20 miles after I installed ec tune, cel came up. So will see on Tuesday, whats the verdict
Reply 0
Nov 22, 2014 | 12:06 AM
  #58
Quote: KPONTI - Appreciate the suggestions, but this hiccup/bucking issue started a few years ago when I reflashed the car with the first tune. After I installed the 82mm TB, the issue is even more pronounced and makes the car unpleasant to drive. I changed the plugs about 6 months ago and lubricated the plug wires with dialectric grease, they are all snapped on tight. That rubber snorkel is not as tight on the 82mm S550 TB as the stock snorkel was on the stock TB, so I was planning on installing an aftermarket aluminum pipe with cone filter setup and silicone coupler to get rid of that rubber Y, but haven't had time to research aftermarket filter kits. If you were able to get that silicone coupler to seal properly with the MB y pipe, please post some pictures of your setup. I've been getting the P505 - idle malfunction code intermittently and can't find any vacuum leaks anywhere. I'm convinced the bucking/hiccup issue is the tune and Tony is going to help me reprogram the ECU later this week and I'll post an update once it is done.
Reply 0
Nov 22, 2014 | 06:53 AM
  #59
man, turn that coupler over... spectre is the last brand i would want advertised on an amg...
Reply 0
Nov 22, 2014 | 07:02 AM
  #60
This is the kit and n my car no flange and OEM mb tb with pcv port and no pin swap
Reply 0
Nov 22, 2014 | 09:01 AM
  #61
Quote: This is the kit and n my car no flange and OEM mb tb with pcv port and no pin swap
Shardul
Is that the SL55 Y-pipe, 1130900329. I'm looking for one. If you have one let me know. Thanks
Reply 0
Nov 22, 2014 | 09:30 AM
  #62
Quote: man, turn that coupler over... spectre is the last brand i would want advertised on an amg...
Lol that highly expensive $15 to $25k AMG should not have a cheap part on it. And no I am not advertising. I did want to show how the exact part from Amazon fit.
Anyway since installing this piece with no change in my tune (EC clutched pulley tune), I have not had that map cel since and I am almost at 1000 miles so far. No bucking either
Reply 0
Nov 22, 2014 | 05:43 PM
  #63
I have Shardul's setup, my TB is an MB S550 82mm unit and the y-pipe is held on by the air filter boxes, the clips wouldn't work so I Dremeled them off. I'm not convinced the seal is perfect, so I'm going to switch to an aluminum intake system with a silicone coupler which should also make the supercharger whine louder.
Reply 0
Nov 22, 2014 | 05:47 PM
  #64
Reply 0
Nov 22, 2014 | 05:49 PM
  #65
Is there a specific place that makes you trigger the hiccup or code, in other words can you be sure driving a specific hill will make it trigger ?
Reply 0
Nov 22, 2014 | 06:16 PM
  #66
My tip-in hiccup seems to happen between 1800 and 2500 RPM after I either accelerate from a stop, let off briefly and then ease back on the throttle or when I'm cruising at slower speeds, decel, and then ease back on the accelerator. Car does the stutter/hiccup thing, it feels like fuel is being cut for a split second, but I don't have an AFR gauge on it to confirm (yet). Suspension mode I'm in makes no difference and it happens in manual shift mode also. I always have ESP off as well, whether it's on or off doesn't seem to make a difference. I can reproduce it anytime at lower speeds below say, 25 mph. At higher speeds, it doesn't manifest itself.
I missed Tony on Friday so was unable to retune my ECU. Will try again next week.
Reply 0
Nov 22, 2014 | 06:31 PM
  #67
Ok take off the y pipe just leave the tb open and see if you can replicate it that way.
I have driven for testing once with no intake just bare tb so as long as you don't go anywhere dirty you will be fine.
Reply 0
Nov 23, 2014 | 12:26 AM
  #68
Quote:
That's exactly how my car was setup and I do not have a Mercedes TB. Holding on via airbox clips certainly cannot provide a good seal. This is the same area that that when that tube comes loose the car runs like crap
Reply 0
Nov 23, 2014 | 10:43 AM
  #69
Mrweelr
In the first picture is that two gasket you are running on the T/B? where did you get them. Thanks
Reply 0
Nov 23, 2014 | 12:23 PM
  #70
No, that's the rubber ring that came out of the 82mm y-pipe snorkel. The Eurocharged instructions were to snap out and remove the plastic ring and flip the rubber ring, but I'm not satisfied with the seal there. Will switch to a cold air intake with silicone coupler soon as I just passed CA emissions and don't need to worry about inspection for another 2 years.
Reply 0
Nov 23, 2014 | 11:14 PM
  #71
Quote: No, that's the rubber ring that came out of the 82mm y-pipe snorkel. The Eurocharged instructions were to snap out and remove the plastic ring and flip the rubber ring, but I'm not satisfied with the seal there. Will switch to a cold air intake with silicone coupler soon as I just passed CA emissions and don't need to worry about inspection for another 2 years.
Mrweelr
Interesting! Thanks for the reply. Do you still have the Eurocharged instructions?
Thanks again.
Reply 0
Nov 24, 2014 | 01:28 AM
  #72
Same instructions I got from Eurocharged just 1000 miles ago. I installed the $12 coupler instead
Reply 0
Nov 24, 2014 | 01:34 PM
  #73
Quote: Same instructions I got from Eurocharged just 1000 miles ago. I installed the $12 coupler instead
Has the coupler improved driveability?
Reply 0
Nov 24, 2014 | 05:19 PM
  #74
Quote: Has the coupler improved driveability?
Serious improvement in driveability! Don't know if mine was just bad at sealing or what but even wot shifts are much more improved.
However the supercharger jerk got a bit more pronounced in 1st and 2nd gears
Reply 0
Nov 25, 2014 | 06:58 AM
  #75
I've read that such "tip-in" issues are often related to wrong mixture on the 55K cars. That leads us to MAP-Sensor and front O2 Sensors.
Since some of you changed the MAP already, try change the front O2 sensors and replace them with BOSCH O2 sensors.
O2 Sensor Lifetime is typically between 60.000-100.000 miles. The richer a car is driven/more often, the earlier the O2 sensors will clog and fail.
I have the very same tip-in drivablility issues, but my car is 100% stock engine wise.
And since the issue got more pronounced slowly over the year and my car reached the supposed "End of Life" with its first set of O2 sensors at ~100.000miles, i'm gonna get them replaced soon.
Reply 0
