ESP inoperative, dealer broke it.
Rating: Thread Rating: 3 votes, 5.00 average.
Old Sep 26, 2011 | 12:20 PM
timeToy's Avatar
'08 E63 Wagon
Angry ESP inoperative, dealer broke it.
Last week, I brought my car to the dealer for the F service and a few warranty items (voice control, tilting mirror in reverse and cargo cover). After a couple of days I got a call, the car is ready, I’m picking it up, while still at the dealership, I open the hatch, and the cargo cover is still broken, it doesn’t go up and down , as it was doing before. I call the service advisor, he came out, fiddle something and boom, it works. Okay, no biggies, these things happen, I leave on my merry way.
Not 5 miles down the highway, I got a message “ESP inoperative”, the car do not seem to lose power or drive funny, just the message, as I try to use cruise control, that is inoperative too! I can confirm that ESP is indeed inoperative as I pull off a huge unintended sideway drift as I accelerated out of a curve!
So I stop on the side of the road and call my service advisor to let him know what happened. The next day the car was in service again to fix the ESP issue.
Fast forward, got a call from the SA, saying that the ESP issue is fixed, that I had wrong size tire in the front (?! No word about the tires in the back !?). I run theses tire for 6 months without any issue, ESP related or other. Picked up the car, not 5 miles down on the highway the ESP light was on again!
Oh and the cargo cover is still not working.
I have no confidence in theses bozos, they are not trying to fix the issues, they break more stuff, they are just trying to find excuses and push back.
Anyone has experience with this issue (BTW, when I check for codes with PLX Kiwi Bluetooth, it says “no code in the ECU”, even when the light is on the dash!)
PS: My tires are 255/40R18 and 285/35R18
Old Sep 26, 2011 | 12:30 PM
GregMB's Avatar
From what I've read, the ESP won't care unless you exceed 2% diameter different (Front / Rear)
Doing the math based on your sizes:
Fronts = 26.03"
Rears = 25.85"
That's less than 1%..... quite a bit less actually. To be fair, all tires measure out differently, and if either the fronts or rears are worn down the numbers could be off by a bit more. However, given how well matched they are in diameter I find it hard to believe that they'd ever exceed 2% even in the worst-case scenario.
I'd take it somewhere else for a second opinion.
-G
Old Sep 26, 2011 | 12:44 PM
AWOL's Avatar
e55
unplug battery for a few mins. Reattach it and slowly turn the steering wheel from lock to lock.
That may do the trick as it happens to me when I switch batteries from lightweight to the stocker.
Old Sep 26, 2011 | 12:46 PM
timeToy's Avatar
'08 E63 Wagon
Awesome, is there a fuse I can use instead ?
Old Sep 26, 2011 | 09:50 PM
timeToy's Avatar
'08 E63 Wagon
Thanks guys, that seemed to take care of it.
Old Sep 26, 2011 | 09:58 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Don't forget TimeToy to resych ESP or it will come back!! With car parked and idling, turn your steering wheel end to end a few times. Let's say 2 times each way. Don't ask me how but it resynchs ESP.
If you are back here reading it after it did it again, that is what happened. Unplug and try one more time.
Old Sep 26, 2011 | 11:12 PM
benz_addict's Avatar
V12TT
Got the same message when I had an odd spare on the rear right wheel. Rolling diameter was different and ESP went crazy. Got two new potenzas for the rear and it's been working fine since.
Old Sep 26, 2011 | 11:18 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Those tyre sizes wont cause an issue. Sounds a little like they are guessing.
I would be quite direct with them and ask if once you took it back with inop ESP if they scanned for fault codes and if so what fault codes were logged. There are many more codes that can be logged than ever before and they give a really good indication of what dirrection to head in diagnosing issues and what components require inspection/testing, guessing and even educated guessing really isn't required in 99% of cases. Fault codes arent a diagnosis by themselves but they do provide alot of information to assist with diagnosis.
Did you happen to get a wheel alignment at this service? A poor wheel alignment can even cause ESP shutdown.
Forget the disconnect battery stuff, there is a issue, weather it be co-incidental or caused by the dealer, and it needs to be identified to prevent reoccurence.
Old Sep 27, 2011 | 12:59 PM
timeToy's Avatar
'08 E63 Wagon
Thanks to everyone, the lock to lock steering wheel action fixed it.
The concern is now the utter incompetence of the dealer. (old tune...)
Old Sep 27, 2011 | 09:29 PM
Ausmbtech's Avatar
Doesn't mean it wont happen again, seeing it happened whilst you were driving I'd get it looked at, you dont want esp to shut down when you need to most.
Old Sep 30, 2011 | 07:33 PM
timeToy's Avatar
'08 E63 Wagon
Yup, it did happened again, this time I dealt with the "Client Care Manager" at the dealership; I guess they spend a little more time, because they found that the control module for the steering wheel angle sensor was toast, they replaced it under warranty. No more issues.
Old Sep 30, 2011 | 07:34 PM
AWOL's Avatar
e55
nice
Old Oct 1, 2011 | 06:01 AM
Hyperlite's Avatar
2005 E55 AMG
lol people actually drive with esp on???
If your having trouble with a dealer just try finding an indie shop with merc experience or someone who used to work for merc.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
