11s with street tires club !!!
Old Sep 29, 2011 | 12:52 AM
skratch77's Avatar
2005 E55
Originally Posted by AKnight55
I thought you were selling the beast? Ive heard that story before lolll
im afraid it might be gone soon,guy that looked at it the other day came with a bank check in my name for 28k and he offered 29k max.
I told him 30 and its yours.
Old Sep 29, 2011 | 01:02 AM
BenzoBoi's Avatar
Super Moderator
W221
Originally Posted by skratch77
Thanks bro!!! Check out your old tb in my sig
Nice nice!
Glad it's helpin you get faster my friend! Next thing you know, you'll be passin me by in the quarter!
Old Sep 29, 2011 | 02:33 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by GT-ER
That's insane! What pressure? Mine are 19's.
i ran consistent 1.71's on the heavy 19" rims you see in my sig and my t1r's were set at street psi (36). don't worry...the tires will outperform most people!
Old Sep 29, 2011 | 06:35 AM
motorkas's Avatar
a Rivera...via a Custom 24, Strat and Les Paul
Yep - if I'm not mistaken - Clayton was running 11.4's on ALL SEASON TIRES (Conti DWS's). . . granted, not the same platform but I would argue it's even harder to keep traction in the TT...
my best on street tires was an 11.7 with a 1.7 60' at 119 (conti's DW's) and that was with just the Kleemann headers and a box tune - once the pulley came on - couldn't get lower than 11.8 with a 1.9 60' (same 19 street tires)....Next week - going to see what she can do with DRs
Old Sep 29, 2011 | 09:18 AM
Benz-O-Rama's Avatar
Good memory, BT. Yeah, I turned 8 11.4x that day on 18" all season tires all with 1.7x 60'.
I was also able to cut 1.7x 60's on my 20" Contisport 3's.
Didn't I cut a 1.70 on your street tires once? It was either yours or Sunir's SL55, that I did that with. Can't remember....
Old Sep 29, 2011 | 09:22 AM
chawkins2001's Avatar
2006 E55 AMG
You killing it homey
Old Sep 29, 2011 | 09:30 AM
  #32
motorkas's Avatar
IF you meant "didn't I cut a 1.7 on your street tires, and then in doing a burnout that caked rubber on your car that I'm still peeling off and then have one of my rears with 7/32 tread left "mysterious" go flat the next day" - then yes
Old Sep 29, 2011 | 09:39 AM
  #33
Don't bore me with the minutia, son.
I took it easy on your car. You should've seen what I did to Sunir's SL55! Ask him at the MIR rental coming up.
Found one of my all-season slips:
Was very close to a 1.69!
http://www.dragtimes.com/2005-Merced...ecs-20775.html
Old Sep 29, 2011 | 10:13 AM
  #34
cal1's Avatar
SL55, ML500 & Acura TL
About 25 psi. I had the suspension raised to the highest level and softest ride. Also, did a burnout. I drove around the water and then backed in to it. It was a short burnout maybe three seconds or so.
So can I join the club? I'm the car on the right.
Old Sep 29, 2011 | 10:31 AM
  #35
skratch77's Avatar
2005 E55
Niceeee
Im uploading mine now.This track day was about seeing why my car was failing up top end from last dyno and last weeks track day.
I did 4 runs in a row(check the time on the slips)and the car was trapping the same depending on the 60ft.
I was trapping 115 last week and the a/f was in the 10s on the dyno.After I tightened up the plugs the car felt way smoother and faster on the street and now these trap speeds prove the power is back!!!
Ill be hitting the dyno next week with the plugs torqued right...I also had no air filters last week at the track and last night I had them in so I pick up 1.5-2.0 mph with no filters everytime I run no filters!!!
I was so upset my car was trapping 115 with no filters and new something was up.with no filters I usually trap 96-97 in the 1/8 and on race gas I hit almost 99 on my PB run last year
Old Sep 29, 2011 | 12:46 PM
  #36
Forrest Gump 9's Avatar
shrimp boat
Congrats man!!
So what are the differences between this and your 11.36 PB pass (beside the tires)?
Old Sep 29, 2011 | 01:21 PM
  #37
skratch77's Avatar
2005 E55
Originally Posted by Forrest Gump 9
Congrats man!!
On my best i was on 109oct no filters drag radials and 48 degree weather.
Last night was pump and 100% the way i drive it everyday.
Iv added 80mm tb since my pb but temps yesterday were like 68-70 vs 46-50
Old Sep 29, 2011 | 02:16 PM
  #38
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
I want to see 10s out this thing.. what happened to the BFGs you had?
Old Sep 29, 2011 | 03:30 PM
  #39
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
I didn't know running 11's on street tires was such a big deal. My friend took my car on a memorial cruise. Called and asked if he could run it down the track. "I said sure, why not" pulled 11.9 with a 1.7 60' 90 degree weather and 120 degree track temp on nitto
Old Sep 29, 2011 | 03:31 PM
  #40
E55Bullet's Avatar
Inovs* 285-18
Old Sep 29, 2011 | 03:35 PM
  #41
Limen's Avatar
E55 AMG, CL65 AMG, S8, S6, E30 M3, Z3MC
Originally Posted by benz_addict
I want to be in mid 11s with at-least 120 trap
Looks like I got alot of more modding to do $$$
Carfull what you wish for. Like others have said, if you go under 11.5, your kicked off the track for not having a cage/roll bar...ask me how I know..
Old Sep 29, 2011 | 03:56 PM
  #42
cal1's Avatar
It was for me. You get to join the club too or your friend does
Old Sep 29, 2011 | 07:42 PM
  #43
E55Bullet's Avatar
Lol I guess he does. You ran my car into the 11's. Was it on drags then?
Old Sep 29, 2011 | 08:08 PM
  #44
cal1's Avatar
Yep, it was on drags so doesn't count. So when are you going to run sub 11.5? let me know so I can watch you get kicked off the track
Old Sep 29, 2011 | 08:16 PM
  #45
E55Bullet's Avatar
Ha! I have 16' wheels with ET street tires, An 82mm sitting in my garage and a rear mount tank in the same place, whenever I get all that done Ill be fighting the low 11-10 range
Old Sep 29, 2011 | 08:19 PM
  #46
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
Inovs* 285-18
Nitto INvos are just like running a DR. Soft compound and hook great . we managed the best times on the NItto invos's 285 19s . 22 psi in the rears with 35 psi fronts
best 60 0 1.80 and best 1/4 11.95 at 117.65 .
Old Sep 29, 2011 | 08:59 PM
  #47
skratch77's Avatar
2005 E55
I should of metioned running 11s with street tires at NED where they never prep the track.
My best 60ft is like 1.725 on M/Ts
Getting a 1.7 60 would put me mid to low 11s
Old Sep 29, 2011 | 09:17 PM
  #48
cal1's Avatar
and you will need a new tune. When are we going for it?
Old Sep 29, 2011 | 09:20 PM
  #49
E55Bullet's Avatar
Once I get my crap together I'll get everyone and we will make a road trip to Chicago and have it done up there (down there)
Old Sep 29, 2011 | 09:33 PM
  #50
Hammer Down's Avatar
2015 E63S, 2018 E63S
NED track prep sounds a little like Sac's track prep
