trans shifting issues
Old Sep 30, 2011 | 08:04 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
when driving in sport mode sometimes i'll manually downshift and noticed recently that the trans wouldn't hold the gear and shift right back up as if it was still in "d". so i pushed the mode selector button and it would only toggle between "s" and "c" mode with no option for "m"!
it will do this intermittently during every drive. any ideas?
Old Sep 30, 2011 | 09:00 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Any codes? The trans will push a code to the trans module which then will send a error code to the primary ECU. Something is not right though.
Any leaks, fluid level, recent trans service? Common issue is a leaking electrical socket located on the trans. It can leak, then in no time send trans fluid straight up into the trans module located under the passenger footwell causing issues requiring removal and a thorough cleaning.
Old Sep 30, 2011 | 09:32 PM
chiromikey's Avatar
no codes. my 13 pin connector was replaced a while ago and isn't leaking and tcu connectors are dry.
Old Sep 30, 2011 | 09:34 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
sounds like a bad tcu or bad programming...
Old Oct 27, 2011 | 03:35 AM
chiromikey's Avatar
just an update and fyi. this was the result of a bad engine oil temp sensor. if the trans thinks the engine oil is too hot it will lock you out of manual mode.
Old Oct 27, 2011 | 03:41 AM
pearlpower's Avatar
no codes or messages of any sort?
Old Oct 27, 2011 | 08:18 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
very interesting! How did you find out the engine temp sensor was the problem. Is the oil temp sensor built into the oil level sensor?
Old Oct 27, 2011 | 09:54 AM
GT-ER's Avatar
2005 E55 AMG
LOL...x2. Good work!
Old Oct 27, 2011 | 10:11 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
He found out from the mac daddy of Benz mechanics. My buddy Ken! Friggin guy is a machine.
Old Oct 27, 2011 | 04:36 PM
chiromikey's Avatar
yep, as jim already knows, before i could even finish describing the symptoms to ken he was already giving me the answer!
Old Oct 27, 2011 | 05:12 PM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Too bad I just saw this thread else I could have helped out as I went through this a year ago with a bad Oil level sensor(i'm assuming the same sensor unit measures the temp). Argued with the master tech for almost a week about this issue but he kept on giving me the "its supposed to work that way since its not a manual transmission...". The issue went away after I had them fix my oil level sensor because of random readings and messages. Eventually it made sense because the whole point seemed to be to keep the Engine RPMs low by using of the transmission. Mine would jump from M mode to sport D. Glad you got this resolved. Can be a scary thing when the car shifts gears and launches forward in traffic.
Old Oct 27, 2011 | 05:21 PM
chiromikey's Avatar
yeah, where the heck were you when i needed you! lol. i do find it amazing how little many techs know about amg's...or even worse what they "think" they know. it's nice to know there are at least a few good ones like ken and scott.
