Floored Fab. Headers= P2098 code
Old Oct 1, 2011 | 12:36 PM
E55amg/FD3S's Avatar
03 e55
Anyone here with FF headers getting the check engine light due to code P2098?
If so, how did you fix the problem? My setup consists of headers along with 200 cell race cats. to stock mufflers. Thanks for any input!
Old Oct 1, 2011 | 01:03 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
What does that code mean? Is it an O2 sensor code?
Old Oct 1, 2011 | 01:19 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
what tune are you running?
Old Oct 1, 2011 | 01:28 PM
03 e55
Post cat. lean. Eurocharged tune. Car runs good. Code started popping up after about 2 months from initial retune. Was told maybe it's the way the 02 wires were extended. Strange thing is for the first few months I never got a code.
Old Oct 1, 2011 | 02:03 PM
It could be the extension of the sensors
Old Oct 1, 2011 | 02:06 PM
chawkins2001's Avatar
2006 E55 AMG
I have that setup with no cats, and been code free for a few months. I also got a new toon to go with the headers.
Old Oct 1, 2011 | 02:55 PM
chiromikey's Avatar
might be a tuning issue or as simple as an o2 sensor going bad. i never have and never will buy into the whole issue about extending wiring to the o2 sensors being a problem. i ran extended sensors for 3yrs and never threw one single cel until i got a tune from renntech.
Old Oct 1, 2011 | 03:06 PM
03 e55
Thanks for all the replies! I'll take a look at the condition of the rear O2's.
Old Mar 6, 2012 | 12:25 PM
jmb614's Avatar
E55 AMG
Did you ever get this resolved? I also have a EC tune with this code and MBH headers. The code popped less than a week after having the headers installed.
I've installed new O2 sensors and had the connections soldered, (which isn't the easiest to do with silver core wire), checked for exhaust leaks (none) and had 90 degree bung extenders installed. The one common denominator that I have seen on the forums is the EC tune.
Is anyone else experiencing this issue? Appears I have hit a wall with this, anyone else have an idea before I place a piece of black tape over the check engine light.
Old Mar 6, 2012 | 12:50 PM
xpl0sive's Avatar
CLS55 AMG
procedure posted in the other thread....
Secondary O2 can be turned off and you can take them out with star diag, development data, control unit adaptation, variant coding, implizite codierung... item nb 183.
Old Mar 6, 2012 | 01:02 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
Mine does it as well but I have an OE tune so I don't think it is tune specific given that OE has a number of customers with no problems using floored fab. I'm going to check my wiring again since i get it for both sides P2096/P2098. My secondary O2 sensors are off within my tune but I'll try and do it in Star as xpl0sive describes...
Old Mar 6, 2012 | 01:06 PM
jmb614's Avatar
E55 AMG
Please let me know if that works. If so I'll have to locate someone with Star or ship the ECU off to Kleeman.
Old Mar 6, 2012 | 01:34 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
i had this problem after getting long tubes installed and it turned out that the shop installed the upstream and downstream sensors in reverse... once i swapped positions the codes went away and have been gone since.
https://mbworld.org/forums/w211-amg/...t-problem.html
Old Mar 6, 2012 | 02:03 PM
jmb614's Avatar
E55 AMG
I thought about that too after reading your thread when the code started popping up after the header install; but I verified a few days ago that they are connected correctly.
Old Mar 6, 2012 | 03:59 PM
chiromikey's Avatar
i went back to my original kleemann tune and have not seen an o2 code since! it's definitely tune related...
Old Mar 6, 2012 | 04:06 PM
komp55's Avatar
ML550
I'm running MBH long tubes and cats with an OE tune. Downstream sensors are extended and on. No CELs, no issues.
Old Mar 6, 2012 | 05:03 PM
vipermike's Avatar
Viper SRT-10, CLS 55 AMG, 2012 Tacoma Off Road 4x4
I'm also running MBH long tubes and no cats with an OE tune. I had the down stream o2's turned off, no issues...
Old Apr 26, 2012 | 04:18 PM
MikesE55's Avatar
E55
I am looking for a Floored fab Header system for My E55 with High flow cats and x pipe
Old Apr 26, 2012 | 04:20 PM
2006 E55 AMG
PM sent, I will sell you mine
Old Apr 26, 2012 | 04:25 PM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
U interested in a full FF used set made from SS?
Requires shipping Over seas though
Old Apr 26, 2012 | 04:42 PM
ahmad0658's Avatar
Brabus K8 E55 05
Can you pm me how much, I have one friend in kuwait who is looking for some LT.
Old Apr 26, 2012 | 06:30 PM
I Like Soup's Avatar
2003 E55 AMG
I have Floored Fab long tube headers and after a couple of months, yep, CEL.
Old Apr 26, 2012 | 09:43 PM
305-E55's Avatar
2017 Charger Hellcat
+1,Prefer without cats if possible..
Old Apr 26, 2012 | 10:21 PM
jmb614's Avatar
E55 AMG
After spending close to $500 diagnosing the code, I had the car re-tuned and it went away.
Old Apr 27, 2012 | 02:31 AM
MikesE55's Avatar
E55
I would be ,what is included in the system and how much are you asking for them.
