HOOKED UP BATTERY WRONG
Old Oct 18, 2011 | 09:46 PM
GRAFH's Avatar
2005 E55 AMG
Guys, I accidentally tried to hook up the small battery under the air filter wrong. Reverse polarity. It was only for a few seconds until I realized what was going on. Now I have no power anywhere car is completely dead. I checked all the fuses and relays under the hood, in the rear trunk drivers side and also the ones next to the big trunk battery. All are fine. Am I missing one or two somewhere?
Old Oct 18, 2011 | 11:46 PM
O-55's Avatar
2005 E55, 2009 VW GLI
These are shots in the dark, but things I would check would be the aux battery relay or the BCM. The BCM may require STAR
Hopefully some pros will chime in and offer other items to look out for.
Edit:
This is a crappy photo, but it should give you an idea of where the aux battery relay is...
Regards,
Oscar
Old Oct 19, 2011 | 07:00 AM
GRAFH's Avatar
2005 E55 AMG
Thanks for the help, in that location is the cabin filter and battery. I don't see a relay like that.
Old Oct 19, 2011 | 07:19 AM
hyperion667's Avatar
2012 CLS63
lol
Old Mar 1, 2015 | 02:21 PM
Beast55AMG's Avatar
2005 E55 AMG, 2006 SL65 AMG
What was the end result?
Hi, I know this was posted 4 years ago but what was the final answer to your question?
May car results has a similar issue after installing headers and dropping the manifold on the starter and a bunch of sparks shot out. Know the car has no electricity.
Thanks!
Ian
Old Mar 2, 2015 | 01:59 PM
desired_speeds's Avatar
2007 SL55 AMG
there is a large fuse block under the carpet in the passenger side kick panel. Check all those fuses and go from there.
