what does our map sensor max out at?
Car is a absolute monster in the colder weather and just when I thought everything was clutch this comes up.
Meaning they are 0psig, 7.25psig, 14.5psi, 21.75psig and 29psig.
The issue I see here is that I'm sure a lot of people go above 14.5psi in these cars ( I'm almost there myself ) but the next one up is 21.75psi which is high....hmmmmmmmmmm....
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
The throttle felt weird after and was really sensitive at very little throttle input would almost jerk the car.
Its been really cold with high pressure up here lately and that might have to do with it.
I went to the gym and parked the car for about 45 min and then drove around a little and the pending code went away without clearing the ecu.
I saw over 30 psi on the intake manifold pressure while I was looking at the gage on my cell.
Could be a bad sensor or just a fluke?I did the tb not to long ago so the blower had to come off,Im thinking there might be a leak maybe also.
what tb do you have?
I have pins 1-4 and and not 5-6 I think I swapped 2-3 instead
It bolts up perfect and I get 2.0-2.4 tps % in drive and no codes at all are coming up from the tb.
I have a spare oem 80mm that I bought just incase the amg 80mm caused codes but it didnt.
250 and its yours!!!
what are you mods so far?did you end up installing a bigger tb yet? let us know if you get this same code.
from the looks of it tbal got this same code when he took his tb off to do the tb grind.I think I lossened up the map sensor harness the other day taking the tb off to put a better sealer on it and maybe the harness is a little loose that is casuing the code.
I only got the code once but Im sure it will come up again.Ill take the intake off on sat and double check the map harness.
enless someone is running 25 psi we are fine
Any thoughts on that code having something to do with the intake air temp sensor?
