Gauging Interest in Custom intercooler tank
This will consist of:
2.5-4 gal tank in the trunk
Lines from the tank to the blower with all fittings
Pump
install instructions
Does anyone have any interest in this? If so please let me know ill be more than happy to help my fellow members
this is what you all need
1. rear tank from dad intercooler tanks
2. rule2000 12v non automatic in tank bilge pump 100 on amazon
3. 50ft of goodyear 3/4 inch heater hose 25 on ebay
5. Male 3/4 PVC drain valve 5 at home depot
6. screw clamps 90 cent at home depot
7. couple of 90 barb fitting if you need them so the hose doesnot kink 97 cents at home depot
8. some DEI heat wrap to cover pipes if the get close to exhaust tubing
Tap fuse F13 on driver side fuse panel in trunk to get a switched 12v
Remember to isolate the engine and s/c cooling system. Once this is done rear tank will self bleed the system
Look at this thread for pics and more info
http://www.**************.com/forum/...ad.php?t=13353
