Where to buy plug n play 80/82mm tb?
Rating: Thread Rating: 2 votes, 3.00 average.
Old Dec 11, 2011 | 12:13 AM
ArmoE55's Avatar
2006 E55
I'm looking for a kit that is plug and play without CELs or other codes. A kit with everything needed for install without headaches...is there such a kit on the market?
I did a search and it seems TTM sells one, but they have one of the worst website around - you can't find ANYTHING and no prices etc.
Forrest Gump 9, I sent you a PM because I remember you were selling your 80 and 82 tb, I have dibs on one if you still have them!
Old Dec 11, 2011 | 01:08 AM
lowprofile's Avatar
E55
You are correct, the website is currently being updated.
TTM (631) 420-1500 EST
Old Dec 11, 2011 | 01:29 AM
AMGPilot's Avatar
2004 E55
'08 SL55 is your friend
113 140 0912 is the supercharger snout
113 140 01 04 is the Throttle Body you want
Swap pins 5 and 6 iirc and you're good to go
Old Dec 11, 2011 | 08:57 AM
GT-ER's Avatar
2005 E55 AMG
And the Y-pipe?
Old Dec 11, 2011 | 09:48 AM
Bramage's Avatar
F-250
Call Bruce at TTM. I'm sure he will update his website soon. I think he has just been busy RUNNING 10's ALL DAY LONG!!!!
Old Dec 11, 2011 | 11:40 AM
AMGPilot's Avatar
2004 E55
Originally Posted by GT-ER
And the Y-pipe?
Yes from the SL55
Old Dec 11, 2011 | 11:51 AM
GT-ER's Avatar
2005 E55 AMG
Yes from the SL55
Do you happen to have the part number?
Old Dec 11, 2011 | 11:56 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
82mm setup
-MB 82mm t/b: 2731410325
-82mm t/b gasket: 2731410680- 14.61 retail
-80mm s/c inlet: 1131400912- 436.80 retail
-s/c inlet gasket: 1131410780- 13.78 retail
-80mm Y-pipe: 1130900329- 286 retail
Old Dec 11, 2011 | 12:00 PM
ArmoE55's Avatar
2006 E55
Originally Posted by pearlpower
82mm setup
For 82mm TB setup, all I need is to spend $7xx bucks ?
Old Dec 11, 2011 | 12:15 PM
pearlpower's Avatar
Still need TB, price not listed. Another route is to simply machine 1/2" aluminum block, weld it to the stock snout, bore that out to match, gasket, y-pipe.
Old Dec 11, 2011 | 01:25 PM
skratch77's Avatar
2005 E55
Also you need to bore out the 80mm inlet because it will cause turbulence from a bigger tb like the 82.
Ohh and good luck trying to get your old cable off your tb.so you would need a tb cable that's about 80-100to going from memory.
Old Dec 11, 2011 | 01:31 PM
Bramage's Avatar
F-250
The parts list (+ a TB) above will give you the hardware, but the TB will not mount to the snout, it has a different bolt pattern. Bruce (TTM) does the machine work to mate the TB to the snout, and modifies the intake and gaskets to be plug and play. There is quite a bit of machine work involved. (I think machine work would run you around $500, but don't quote me, that was probably a bro deal for yours truly, and I think I'm almost sponsored .)
If you want plug and play, give Bruce a call. If you want to build a kit.. that's a different story, and there are many write ups. Personally, Ill get the kit from Bruce and save the aggravation.
Old Dec 11, 2011 | 01:51 PM
AMGPilot's Avatar
2004 E55
Incorrect. The parts list for the '08 SL55 requires ZERO modifications other than than swapping pin 5 and 6
Old Dec 11, 2011 | 02:13 PM
skratch77's Avatar
2005 E55
500 to bore the opening 2mm? Wow im in the wrong line of work lol I paid 50 bucks and my friend powder coated it for free.
For the screws that bolt up on the tb all you need to do is drill out one hole to make it bigger to give you enough room to move the tb over to line up.
Or just buy my mb oem that will bolt right up and you don't need to bore anything to make it bolt up
Old Dec 11, 2011 | 03:59 PM
tbal's Avatar
Haters crazy
82mm setup
So which part numbers work? I'm seeing a lot of different numbers. Do Sl55 only have 80+ mm? I could swear somebody said the s550s, and sl550s did as well?
Old Dec 11, 2011 | 05:23 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
82mm setup
This is correct
Do not do this
This is a must ^^^^^
Old Dec 11, 2011 | 05:44 PM
pearlpower's Avatar
https://mbworld.org/forums/w211-amg/...ttle-body.html
Old Dec 11, 2011 | 05:48 PM
lowprofile's Avatar
E55
Actually he was correct, as he was referring to the part list posted by pearlpower.
However, did you fail to mention that running the 80mm(real measurement of only 78mm btw) will eliminate the factory pcv system?
Old Dec 11, 2011 | 05:50 PM
Bramage's Avatar
F-250
No, I was talking about adding material to the 80mm snout and re-tapping the snout to accept the 82mm TB. Also, boring out the shout to match the diameter of the TB.
80mm would be easier, but I think 82mm would be a better mod if going to all this trouble.
Old Dec 11, 2011 | 06:56 PM
This the correct way to do it https://mbworld.org/forums/4731340-post4.html
Old Dec 11, 2011 | 09:06 PM
ArmoE55's Avatar
2006 E55
What does pcv system mean? Noob here
Old Dec 12, 2011 | 12:58 AM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
+1 I prefer Hammer Down's recommendation. Mine has an extra flange bolted on the end which sets the TB further back. It works ok but is a stretch for the y-pipes when you want to hook up to the airboxes.
Originally Posted by Hammer Down
This is correct
Do not do this
Old Dec 12, 2011 | 01:38 AM
AMGPilot's Avatar
2004 E55
No it doesn't. Everything for the PVC system is there, after all it's a factory setup for the S550, SL55 and SL550
Old Dec 12, 2011 | 02:45 AM
lowprofile's Avatar
E55
I'm clear on the factory setup. But is that the same as what it used on the E55? Negative. So now you need to modify this as well, not just a two pin swap anymore. The E55 pcv is plumbed into the vaccum side of the engine. There is no source for ported vacuum on the throttle body you are recommending.
Armo, PCV= positive crankcase ventilation.
Old Dec 12, 2011 | 09:13 AM
skratch77's Avatar
2005 E55
You can run the pcv right into the inlet and thats how the sl55 does it i think.my amg 80 doesn't have a hole at all and i drilled one in.after that i saw it was on the vac side ,i could of saved alot of time by just running the pcv to one of the ports on the inlet.
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
