Sharduls Modified Stock E55 Exhasut Manifolds
a unicorn tuned p30 e63
This is what shardul wrote on original post when he posted them. Only reason for selling is because i need to free up some money.
" I have has these on my car for a about a year now and yes they do produce about 15 to 20 rwhp over the stock setup. The stock bottle neck flange has been cut and the manifold is mated to 3” piping and 3” high flow cats. All the angles of the piping is like stock so nothing has to be removed while installing not even the steering linkage. Keep in mind all my O2 sensors are on and I don’t have and CEL with these manifolds. This may be a good mod for you California guys who have to do a visual inspection to pass smog. In terms of sound they are louder than the stock ones.
Manifolds will come in one piece until the black line in the picture number 4. Each side will have 2 holes one before and one after cats for the primary and secondary O2 sensors. These bungs are in the stock location so you don’t need to extend O2 harness etc etc. In addition to this the driver side has a bung and a nut for a wideband O2 sensor if you want to install one or use the port while dyno tuning.
https://mbworld.org/forums/engine-pe...manifolds.html
^is a link to the original post with pics.
Im just trying to recover what i paid for them but it seems i might not get that so pm me with your best offer.
Thanks guys
Thanks guys
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
PLATINUM SPONSOR
Damn, I put a lot of blood sweat and tears into making those.
Hope they go to a good home!
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
