Tested the best crank pulley and it has adjustable boost features!
PLATINUM SPONSOR
Yes, this was the secret pulley that a few saw on my engine early on..
I was sent (to test them) a couple early production runs of this new adjustable boost crank pulley (last summer) by Redtooth products and was enthralled with the product! I have a few 195mm kits and my kit with extra boost rings. The fit and balance was better than the stock AMG ring and being all CNC machined VS cast iron like AMG, this pulley is better made. The balancing/harmonic absorbtion material is the same used by most all automotive MFG, so you get a better machined part that uses the best proven design of absorbing crank vibrations. Then with 6 hex head bols, you can change boost rings in a few easy minutes. No pulley hub removal at all, just change outer rings. Outer ring is aluminum and hard coated to help with wear , reduce belt slip and keeps weight low (more power)! The other favorite feature of mine, is that the balancing weight stays around the same 10.7 lbs as the stock set up, so balancing weight is not changed or increased.
The other pulleys were sent out to some of their aftermarket dealers but was happy to get some!!
![](http://i991.photobucket.com/albums/af31/Vitabc/2011-12-12083650.jpg)
![](http://i991.photobucket.com/albums/af31/Vitabc/2011-12-12083701.jpg)
![](http://i991.photobucket.com/albums/af31/Vitabc/2011-10-29132100-1-1.jpg)
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
I like it, dose it have a concentric hub that centers on the HD?
Grade 8s would hold fine, then drill-em & wire.
![](http://www.oldbritts.com/image/52_130202a.jpg)
E55, CTS-V Wagon, Duc 1098R
PLATINUM SPONSOR
Guys this pulley interlocks with the inner hub, so not much load on the bolts and those bolts will hold an easy 100 times the pulley load.. Instructions say use blue lock tight and torque to 25 ft lbs. It was easy to change the outer rings and this part works flawless! I have seen most all the pulley`s ever made for our cranks and nothing like this or that rocks like this.
I ran it hard for over 2000 miles and was perfect! I doubt I am the only person running one, but just may be the most vocal.
__________________
www.ultimatepd.com
www.ultimatepd.com
PLATINUM SPONSOR
I h
__________________
www.ultimatepd.com
www.ultimatepd.com
Your R&D and support is invaluable to the community. This is great for constant tweakers or guys who want a "street" and "race" car. Coupled with the EC box and it's a helluva combination.
The vendor membership isn't THAT expensive is it? I'd be in for $20 to help....
-G
I will throw in fo sho![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
To be a supporting vendor it is a monthly fee, and it is not cheap either, by the way.
It is not a one time fee.
PLATINUM SPONSOR
I made 3 pulley changes on my pulley to test it. I started 185mm, then went to a 190 and then had the custom 200mm battle shield made.
I was thinking we will be trading rings like baseball cards pretty soon.
Thanks everyone, I will post pictures of the hub and ring. It is just a machined hub on the outer ring, that slides into the main steel hub. It is a CNC machined fit part. This project was over a year and half in the making. Special molds had to be made/designed to inject the bonding vibration durameter into the two part hub and all the other details that go with this.
Another cool feature, is that the hub surface that contacts the bearing seal is micro polished to prevent seal wear. If any of you are leaking oil around your seal, it may be that the other pulley`s dont have the right degree of polish or maybe not polished at all, to prevent seal wear.
I will be a sponsor or get on with a sponosr to be able to have FREEDOM OF SPEECH soon. Thanks again, it is a lot of fun knowing so many performance companies that want to make cool parts for the 55 format.
__________________
www.ultimatepd.com
www.ultimatepd.com
