HELP.... Key not recognized
Old Dec 21, 2011 | 06:19 PM
Fly by night's Avatar
E class
Just got my car back from stereo shop
and my keyless start now flashed key not recognized in the dash
What's the issue?
Thanks in advance
Old Dec 21, 2011 | 06:23 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
The issue is you let a stereo shop jack with your car!
Old Dec 21, 2011 | 06:33 PM
E class
I would say correct however they've done numerous installs on cars much nicer than Mercedes and came highly recommended from other Mercedes owners in my area. I did call them and they realize it was working before they startrted doing the install. They suggested unhooking then reconnecting the battery but no luck!
Do I need a new key? I only have one
Old Dec 21, 2011 | 06:42 PM
FASN8N's Avatar
CTSV/6sp Grocery Getter
How old is the battery in your remote?
Old Dec 21, 2011 | 06:52 PM
E class
Hi
Just changed out the 2 batteries in the remote less than a month ago.
Old Dec 21, 2011 | 07:18 PM
berti_00's Avatar
2016 Cls63s AMG
aren't these keys battery less?? they charge while on ignition? at least so i thought
Old Dec 21, 2011 | 07:23 PM
FASN8N's Avatar
Mine will give the same message every now and then, but the car starts just fine. Wish I had a better answer for you
Old Dec 21, 2011 | 07:27 PM
emoving's Avatar
Sounds like you need STAR to get the car to re-recogonize the key.
Old Dec 21, 2011 | 07:53 PM
E class
How would I do that? Just call them?
Old Dec 21, 2011 | 07:55 PM
emoving's Avatar
Originally Posted by Fly by night
Yes, unless someone near you has one.
Old Dec 22, 2011 | 01:13 PM
GregMB's Avatar
You should be able to program the key yourself by putting it in the ignition and rotating the key to the 1st position and let it sit for a couple of hours. Put the rear battery on a charger if you're worried about killing power.
The dash will say something like "Learning Key"... eventually the pairing will be complete and you can use the key as normal. I don't know if you have keyless go, but it works fine for that too.
I bought a new key from the dealer and did this procedure in my own garage and it works perfectly....
-G
Old Dec 22, 2011 | 01:22 PM
emoving's Avatar
-G
So anyone can throw a key in any Benz that they just bought from the dealer and do this. How the hell do you protect yourself from theft?
Old Dec 22, 2011 | 01:31 PM
GregMB's Avatar
Not sure about all the specifics... I needed to provide my VIN to the dealer to buy the replacement key, but I think that was so that they could order the correct one (I needed Keyless GO)
I remember asking MB how I could be sure that the "lost" key could never be used to drive my car in the future. There may have been something the dealer did with STAR to clear the previous keys and only allow the two current ones to work. Honestly, I've forgotten the details about how that all worked. They basically sent me home with the key and told me I could do the pairing myself so I didn't have to wait around for a couple of hours while my car tried to learn it.
My point to the OP was only that if the key was previously paired with the car, the ignition trick might be all that's necessary. It seems unlikely that STAR settings as important as key pairings would be lost simply be disconnecting the battery?!
-G
