Official Suvneer E63 Front Conversion Thread
#301
Former Vendor of MBWorld
#303
2012 Volt - 2005 E55 - 2011 G55 - 2013 GL63
Question for you all while I gather the remaining parts:
For the new upper grill where did you all get the small emblem/badge at the top of it?
Who has installed HIDs in these fogs and what did you do to make it all fit properly?
Lastly, how is the light output with HIDs in the fogs?
#304
#305
I got mine from the dealer its about $25.00 and it comes with 3 rubber push in things that you have to insert into the grill.
I have a HID kit on my car and it looks great, the output is very well and bright and thats with 35w canbus..
#306
please help me
thanks
H
#307
'05 C55
I ordered the E63 front end conversion for my '05 E55 along with the CF front lip from Gary. The parts arrived quickly and safely with very good communication from him. I had the bumper cover painted by the body shop I've used for years and I installed it myself in about an hour or so. The CF lip took me about 45 minutes to install as I used pop rivets to hold it on which worked perfectly and secured it very tight against the bumper cover. Everything fit & aligned just right and I'm very happy with the outcome. Gary's service has been first rate and you can't go wrong with this conversion!
#308
which HID bulb size do I use. I have a H7 bulb kit and a 9006 kit laying around and neither seem to fit. So I must be missing something on how this all goes together. I know the new fogs use H7 and the old ones are 9006 but I am at a total loss?!?!?
please help me
thanks
H
please help me
thanks
H
Okay guys here are some pics I took, its pretty easy to do this. You will need a hand tool or some sandpaper, going the manual way may take a while. I used a dremel.
Also the o-ring typically that comes with these adapters are too thick, so swap over the o-ring that came with the bulbs. You can buy these from the net or from me, you will have to mod them. Each fog light will be a little different and adjustments would have to be made with each housing I suspect, so I will leave it up to you to modify them.
If you stop by my shop in Houston you are more than welcome to use my dremel, I would enjoy to shoot the **** with you as we do them. You can scoop these up from me for $13.50 for a pair or $15 a pair shipped. Also you may have to wait a week if I am out of stock. I usually only stock about 10 pairs, they are very slow movers in the Houston market for the shops I deal with. I have H7 HID bulbs also if you need them for $25.00 shipped, you can reuse your current HID ballasts. I have 3000k (yellow), 4300k, 6000k, 8000k, and 10000k.
Dharm
Dharm
#309
Thank you sir!!!
Car looks great, I see you're in Houston hope to meet you soon..
#311
Got my bumper and new lip coming next week, thanks you damn raccoon.
Car has parktronic and distronic please help me ensure I have all needed parts ordered. I plan to transfer my PDC brackets from my old bumper.
Now I am ready to order these parts listed in this thread:
211-887-03-27 Pull For Hood Latch $4.20
211-880-09-03 Inner Plastic Support $27.60
211-880-10-03 Inner Plastic Support $31.80
211-880-07-03 Center Inner Plastic Support $13.20
But are these below recommended or needed for best fitment?
Lower supports (found in another thread):
211-885-07-16 Reinforcement For Lower Bumper $20.40
211-885-08-16 Reinforcement For Lower Bumper $20.40
211-885-03-16 Reinforcement For Lower Bumper center $22.80
Foam behind the bumper:
Can E55 foam go into the E63 bumper with a little trim or is it best to order new foam as well?
211-885-13-37 Impact Absorber Center $20.40
211-885-15-37 Impact Absorber Left $21.60
211-885-16-37 Impact Absorber Right $21.60
Lower Center Mesh:
Does the center mesh it comes with look and perform fine or should I also get the OEM lower center mesh?
211-885-13-53 Center Mesh $151.20
Grill:
Will any ebay grill for a 07+ work for distronic or should I order the OEM grill?
Unknow part number but on parts.com $432.00, extreme price increase over the 55 grill which is $165!!!!
H
Lower Center Mesh:
Grill:
H
photobucket-34688-1344186699856.jpg?t=1344215931
This is a photo before the above mentioned parts were installed. As you can see, the inner plastic supports are swinging in the breeze without them.
#313
#318
OK, I read all 13 pages, but I did not see a write up for fitting the E55 Parking sensors to the Gary Bumper. I know on the OEM (07+) you need to widen the holes and glue the sensors in. Does this bumper accept the sensors without modification?
#319
I have some better quality pics to share. I also installed a 5K HID fog light kit, and lowered the front end.
FWIW, the fogs are really bright and disperse light in every direction. I wouldn't recommend doing this unless you are retrofitting a projector housing, or don't plan on using them with oncoming traffic.
#322
You can transfer your E55 PDC brackets from the old bumper to the new bumper. Just have the body shop to use industrial glue/adhesive. Thanks.
#323
Who has the license plate mounted ? Is compatible with E55 front bumper bracket ? I just don't want get into trouble with cops...... without front license plate kinda PITA over here.
#324
No youll need to get a new bracket for the 63 bumper..New bracket is like $100.. When are you going to do it Charley?
