V8 Kompressor engine - Thinking of adding NOS???
The old girl being a 2004 S55 AMG Kompressor.
Not saying she's not fast enough in standard form, but just on the odd occasion you just need that little bit more.
Anyways, it occured to me that without having to go through all of the above, what if i was to add a NOS system to the equation instead. Instant power when i need it and normal driving when i dont.
Only looking at adding a 100bhp kit.
Anyone else tried it and think it wasnt all that?
Anyone got any opinions about how well this engine would take to it?
Many thanks.
"You'll be lucky if that hundred shot of NOS doesn't blow the welds on the intake!"
He lives his life a 1/4 mile at a time, so I would listen seriously to what he has to say.
-G
Don't destroy an S55K with nos, you might think its the cheaper way out, but it's not.
Do your homework, don't get greedy, set it up correctly, add in the safety features and you will be golden. A 100 shot on a bonestock S55AMG would rape just about any stage 55AMG up and down the highway and on the track. Go for it homey and when done right, you will be very happy with the end result. Don't listen to folks who have no experience running it on their own car but claim to know all the facts
P.S. You'll need the big bottle, and you should probably make that two!
On nitrous, it is the total opposite, when the system sprays you tune the ecu to pull timing. If you don't get greedy with the shot size, the sauce will also have a major cooling effect while making big HP/TQ. Again, if the system does not trigger like it should, you will not be subjected to the advanced timing issue and you should be relatively safe.
my meth kit on the audi uses both meth injection flow rate failsafe and boost controller failsafe so it would also dump boost and obviously not being trying to advance timing at that point.... i know that part works because when i first installed meth on my s4 i didnt get a good tap on the map sensor with the crappy quicktaps it came with and so when i first took it out for test drive i would see the progressive controller go up a few LED's and drop off and car would fall flat on its face...
finally i realized it was dumping boost like it was supposed to do because it wasnt seeing correct flow since the map signal sucked and it was getting intermitant signals lol... i soldered it and no problems after that...
that being said... both nitrous and meth can be equally dangerous if failsafes arent installed.... but i def want to explore running both on my car.... meth for full time cooling/ timing advance and nitrous for whenever i needed a little edge on the highway (prob a 25 shot since in s/c app would equate to a bit more)
