E55W dyno 518whp
the baro pressure that they used is WRONG and usually they hook up the software that pulls that info of the weather station.
that is the lowest baro ever and close to the lowest ever recorded on earth.Enless your dyno was done in the middle of the pacific near the equator with a typhoon about to start lol
I know how the sae system works and have dynod my car more than I can remember and I already looked up your pressure and it was 29.xx not 26
You're always wrong and make the dumbest comments.
Do some research about big pulleys, air temp, and E55 with limited cooling. you've been on this forum long enough...to learn something
Ok wait let me help you....
http://www.**************.com/forum/...ad.php?t=19315
If this car can make 469whp with stock crank pulley, upgrade supercharger pulley, cooling, cat delete on dyno which appears to be a lower reading dyno that a dynojet. why can't we make 518whp with 185MM pulley and TTM fuel setup which has been proven to make 20+whp alone?
That is why I dont use any correction factors in my runs.what the car puts down is what the car puts down that day,that temp and that run.Just like when you go to the 1/4 on different conditions you get better runs in.
you can set the sea but if the weather conditions are not input properly you get a wrong reading.
you are prolly about 490-500whp with proper baro settings
2005 E55 AMG
Take your car to the track with a 2500+DA with ZERO weight reduction and see what you run before you comment on my run.
I myself have had my disagreements with Skratch77 about dyno numbers but he is 100% correct in this topic. The SAE calculations aren't at fault here, it's the dyno's barometer that is not correct.
Keep in mind that the lowest ever recorded on earth was a little under 26. There is no way yours is correct.
Basically 518whp 605 torque with 185 pulley and tune is basically impossible.
When I said net increase I meant what was the baseline dyno?
#32
Administrator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Who cares if its a real 500hp car..... on paper or not. Get it to the track to confirm the numbers. Then the OP can either quiet the non believers or will have to have the car re-dyno'd correctly.
My E55 never dyno'd over 500 hp but it sure did well at the track over here in Cali. So I was happy with the paper snail.
Id rather have it this way than vice a versa.
#34
Dirt Scooters
Ive got headers,tb,injectors, 175(might be a 178) pulley,trunk tank with ice, and i made 537 on a honest dyno jet and that was on a 40 degree day and 2 fans running. A dyno operator can make a car dyno what they want to.
#35
just asked to get my dyno with a 1.17 cf and was a no go lol He said Iwould have to dyno my car way up in the mountains of colorado and have it over 115d out to get that CF lmfao
#36
There's only one way to tell, get that car to the track and video the results. Quarter mile is more accurate than dyno since at the end of the day people want high dyno numbers so they do well on the 1320.
![action](https://mbworld.org/forums/images/smilies/action1.gif)
#37
I'm sure the dyno operator just forgot to reset the correction factor after "tuning" a dyno-queen Civic. OP's 1.17 correction factor is way off. I just looked at two of my dyno pulls (#s below), and your cf should have been around 0.98 - 1.00, not 1.17.
Max Power = 517.44 Max Torque = 587.56
Max Power = 514.68 Max Torque = 585.73
RunFile_002.drf - 2/6/2010 2:32:36 PM Run Type: RO Run Conditions: 72.94 °F, 29.74 in-Hg, Humidity: 26%, SAE: 0.98
RunFile_003.drf - 2/6/2010 2:43:41 PM Run Type: RO Run Conditions: 72.15 °F, 29.75 in-Hg, Humidity: 27%, SAE: 0.98
