THANK YOU SHARDUL AND BROOKE
After you install the heads, tell me how it goes. If all goes well, then I will get the heads........everytime when I think I am about done modding this wagon....I get pulled back in like a little boy in a toy store with a gift card to spend.
Dam you Acid!!!! Now, you are forcing me to get those heads!!!
Well first I will run stock heads with a 190mm pulley and remap my car once engine is rebuilt,
Then i will place race heads and 200mm pulley so I can see what the difference is in power! I am also wondering how these heads will run with kleemann cams...
As this is new ground for me and others I will be doing alot of testing.
Acid
PLATINUM SPONSOR
Acid, thanks! Cant wait to see your 10 second time! That pulley is like ***** envy!
Jack, you are in big trouble now bro..
Acid, Call me if you need any consulting/help! Same if your bother does too. One day install, tune and to the TRACK!!!!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
