Injectors ?? What you think
Old Jan 25, 2012 | 04:43 PM
BRABUS786's Avatar
Stage 3 63
Hey
Guys
Have a look at these injectors and tell me what you think, I have 550cc at the moment and looking to move bigger.
http://www.ebay.co.uk/itm/8-AUDI-Mer...#ht_1499wt_689
Acid
Old Jan 25, 2012 | 04:58 PM
e55amgrocket's Avatar
Dirt Scooters
If your going for E85 you will need bigger injectors with the power your going for
Old Jan 25, 2012 | 05:21 PM
chawkins2001's Avatar
2006 E55 AMG
I went with 1000cc squirtters for my e85 conversion.
Old Jan 25, 2012 | 05:49 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Originally Posted by BRABUS786
Hey
Guys
Acid
Acid, those the style we used to run but they drill them out to make them flow more. At your power level, you need the latest EV14 style header. They are more stable, easier to tune and will perfom much better..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jan 25, 2012 | 06:21 PM
BRABUS786's Avatar
Stage 3 63
So these injectors are not better then the ev14 750cc?
Also I'm not looking to do E85 yet maybe when I got my 5.7 litre bottom end.
Will my 550cc do the job as I am looking to run more then 600rwhp?
Acid
Old Jan 25, 2012 | 11:29 PM
KLR CLS's Avatar
CLS63 PP
750's at our rail pressure will be more like 900+cc/min. Thats alot of fuel, but as long as the tune is scaled correct "should" be fine.
