- Mercedes-Benz C-Class: How to Replace Door Lock Actuator
Step by step instructions for do-it-yourself repairs
Browse all: Exterior Guides
DIY Door Lock Actuator Replacement
http://www.benzworld.org/forums/w211...-actuator.html
I will add that installing new rivets in the window guide is actually easier than bolts, washers, and nuts. Also, the window guide does not have to be removed, just roll the window down about an inch, remove the rivets, and push the bottom of the guide toward the outside of the door so you can wriggle the actuator assembly out.
If you're not doing the driver side door you can skip step number 8.The whole process can be done in an hour. All of the electrical connectors snap right into the door module and it is quite easy.
