Fog light flickering when not even on
Old Feb 1, 2012 | 02:15 PM
purplehayes65's Avatar
05 E55
I noticed this yesterday when I was behind a car that I could see the reflection. The left fog was flickering and then slowly went out. I turned them on and they work fine. Any ideas on what is going on here? Thanks for any help guys!
Old Feb 1, 2012 | 02:31 PM
BlkE55K's Avatar
2010 E350, 2011 ML350, 2003 996TT
Sounds like a switch issue to me. Something is closing the circuit and causing power to run to the flickering fog.
Old Feb 1, 2012 | 04:52 PM
nanayaw6's Avatar
2006 E55, 2006 saab 93 aero, 2010 glk 4m
Are you by chance running LED bulbs in your fog lamps
Old Feb 1, 2012 | 05:20 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
If they are xenon, the unit is starting to go bad.
Old Feb 1, 2012 | 11:36 PM
05 E55
They are the stock lights that came with the 05 so Im guessing that is the xenon lamps. Thanks for the info, I will start looking into getting a replacement.
Old Feb 6, 2012 | 06:10 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
You do know some W211s use the fog lamps as cornering lamps, I don't know how they work but you might want to check your owners manual.
And BTW the stock fog lamps are not Xenon.
Old Feb 6, 2012 | 06:16 PM
nanayaw6's Avatar
The curb illumanation/whatever its called turns on the fogs with the turn signal or when you turn the steering wheel (via steering angle sensor).
I have a feeling previous owner must have put in LED's in OP's car.
