Now this is a Twin Turbo System!!!
2007 E63 AMG, 1991 NSX, 2007 Corvette
Wow, and just when I thought UR was the **** with their turbo upgrades.
This build is pretty impressive. Guess it proves that you can always go faster !!! secret would be keeping it straight...
Very sick car! Its Spiro Pappas' Outlaw 10.5 69 Camaro. The motor is a hemi-headed Sonny Leonard 540 big block running twin 88mm turbos. He crashed his last car running a single 114mm turbo. Car ran in the 6.70s in the 1320. Video of the car doing some shakedown runs here: http://www.youtube.com/watch?v=JKxyHycSEjQ
He crashed this car, hence this new twin turbo build. Makes in excess of 2200 HP without breaking a sweat on relatively low boost. Take a look at the build here: http://v8tvshow.com/forum/index.php/...54.msg954.html
The cylinder heads alone give me a raging hard on. I haven't seen this car make any passes, though I wouldn't mind seeing it go after Tim Lynch's 6.26/232mph world record. And to think that they transmit all of this power to the ground on 10.5" drag slicks...its mind blowing!
Josh: How's the new tune working out for you? Progess on my '69 is slow! Getting the cage and rear end built now and then its off to paint/body.
#34
Chris, Its in the middle of a frame off rotisserie restoration right a street strip setup that will see more street use than anything. It has a 383 with Dart Pro 1 heads, TH400, twin Turbonetics 60MM TO4B's, FAST EFI. Weakest link is my older generation chevy block. Could really use an LSX setup or Dart Little M for a stronger foundation. Would love to see more of your setup!
#36
CL65
http://www.youtube.com/watch?v=eu26WFy4_zQ
The single turbo car, the one he had since high school, is still in tact and has run a best of 6.70.
http://www.youtube.com/watch?v=JKxyH...endscreen&NR=1
