compatability question
Rating: Thread Rating: 2 votes, 5.00 average.
Old Feb 22, 2012 | 06:09 AM
320 dreamer's Avatar
2003 porsche 996 turbo
is the crankshaft diameter at the end were the crank pulley goes the same for the m113 and the m112?
basically can i run a m113k crank pulley on my m112k engine? seems you have simialr sizes as we run but cost is much less! something in the way of a 178 or 180 crank pulley to run stacked with my 65mm s/c pulley
Old Feb 22, 2012 | 06:15 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I can measure the pulley hole and the key way and report back. But what about the offset and spacing off the rings. I have a damaged asp pulley that you can look at.
Old Feb 22, 2012 | 06:26 AM
i have a damaged oem pulley if you want me to send it to you for comparison
Old Feb 22, 2012 | 07:08 AM
GT-ER's Avatar
2005 E55 AMG
C32's only use one belt while E55's use two belts so it's not going to work.
Old Feb 22, 2012 | 06:14 PM
i wondered about that but the new rtr pulley and some others i surfed only had 1 belt setup. pte informed me it was more a 6 rib vs a 8 rib issue more than anything else
Old Feb 22, 2012 | 10:28 PM
GT-ER's Avatar
2005 E55 AMG
1 belt setup for the m113 kompressor engine? Maybe I'm misunderstanding but they ALL have two belts.
Old Feb 23, 2012 | 06:02 AM
you are correct. i was looking at pulley pics and not seeing the smaller rib setup under the larger ring. of course if i can get it to line up its not mandatory to run two belts.
Old Feb 23, 2012 | 07:14 AM
GT-ER's Avatar
2005 E55 AMG
It won't line up though, the difference is HUGE.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
