my hids and leds came in
I will update when there on the car.
I already installed the 6k fog kit and here is the rest.
license plate 6k
front day lights 6k
d2s phillips head lights 6k
and all the interior lights in 6k
license plate 6k
front day lights 6k
![](http://img29.imageshack.us/img29/6880/img20120228102146.jpg)
Yes 100% and its the same company the e55 uses fir stock bulbs.look at my other thread i have all the links on where to buy them cheap.
I paid 99 bucks shipped for those bulbs
yeah everything is matched 6k and yes andrew i got the 14 piece interior kit also.
Ill be at my friends shop tom changining my map sensor and if i have time ill do the inside leds.
My map sensor finallt crapped out and threw a check engine light with rough idle.i got a few codes over the winter but now it went into limp mode so a new sensor is my main priority
Angelo
One word of advice on the license plates lights with the heats sinks. I have had then before and they worked well but just got too hot. The solder on the PCB's got too hot and disintegrated. I eventually with the whole housing swap after the second set went out.
Thanks for the heads up grant! I had some cheap ones last year and they failed on me in less than a month.they would just blink on and off and eventually would stop working
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Angelo
here is a picture of the fogs and my interior wedge leds in the day running lights.Im waiting for a 6-8 led super bright 6k set to put in the day runners but wanted to see how these single leds look.
They look 10x better in person and I got the 6 leds each on the rear for the plate also in 6k.I finished the inside lights on the mirror but I could not figure out how to get the dome light off without breaking something.If anyone knows a trick please let me know.
![](http://img812.imageshack.us/img812/2638/img20120229143811.jpg)
as you can see from the pics on how hard it is to mix and match color temps so everything will match.
I will see how the phillips headlight 6k bulbs look and go from there to get all of them to have the cold ice blue look to them.Once I go threw like 2-4 more sets of leds I will make a thread with all the correct brands/temps that match up well.
