E55 QUESTION
Old Mar 3, 2012 | 10:44 AM
PORSCHEFREAK's Avatar
2009 S63 , 2010 GL350 , 2005 C230, 2007 E350 wagon
Question E55 QUESTION
What is the red pull out plug near the rt rear area of the supercharger? Oil check port or supercharger oil?
Old Mar 3, 2012 | 11:30 AM
moosejaw's Avatar
none
Transmission oil check
Don't open it unless you have a replacement plug
It's only meant to be used once
Old Mar 3, 2012 | 11:33 AM
Question E55
No, I know where the transmission port is. This is on top of the engine in the rt rear corner of the supercharger.
Old Mar 3, 2012 | 11:53 AM
JonMBZ's Avatar
06 C55, 09 E350
Maybe this helps
FLUIDS:
OIL: Must use Mobil 1 SuperSyn European Car Formula 0W-40 or Mobil 1 ESP Formula M 5W-40 holds 9.0- quarts with filter -No engine oil dipstick, must check level on instrument cluster.
FUEL: unleaded PREMIUM of at least 91 octane, capacity 21.12 gal.includes 2.38 gallon reserve.
COOLANT: Mercedes-Benz Anti-corrosion anti-freeze # Q103 0002 holds 13.8 quarts
AUTOMATIC TRANSMISSION: 8.0 quarts of special MB trans fluid-DO NOT USE DEXRON! Mercedes Part number 001 989 21 03 10-No transmission dipstick, do not remove cap!
BRAKE FLUID: DOT 4 PLUS, (4 +) holds 1.1 quarts
POWER STEERING FLUID: MB Power steering fluid # BQ 1320001holds 1.1 quarts
Old Mar 3, 2012 | 11:56 AM
moosejaw's Avatar
none
Thats the transmission level check
Old Mar 3, 2012 | 01:16 PM
claywillard's Avatar
2005 E55 AMG
If you are referring to the red "plug" that can be seen from looking down on engine, it is the check engine oil level port. It is, however, without a dipstick. If you wish to manually check engine oil level, you need to purchase a dipstick to check the oil level from this port. It is also used to extract engine oil using an extraction pump (will only extract oil from the rear section of the two section oil sump pan). Trans fluid check port is hidden between the passenger side Surge Tank and firewall.
Old Mar 3, 2012 | 01:31 PM
Question E55
THANKS CLAYWILLARD, Make's since now! Silly Germans!
The Black night say's "None shall pass without a dipstick!
Old Mar 3, 2012 | 01:37 PM
2005 E55 AMG
lol. no prob.
ps: why porschefreak sig on an mb forum?
Old Mar 3, 2012 | 01:42 PM
E55
AMG is my choice of road going cars, have had 3 now. I race Porsche's on the track. I am President and chief driving instructor of Nord Stern Porsche Club.
Old Mar 3, 2012 | 02:32 PM
cij911's Avatar
one car at a time
So how does MB expect someone to check the oil? I just got my 2006 and was looking for the same...
Old Mar 3, 2012 | 02:45 PM
2005 E55 AMG
Search is your friend.
On board menu provides status of oil level. Or you need to purchase a dipstick...
Old Mar 3, 2012 | 02:53 PM
cij911's Avatar
one car at a time
Sorry I meant it more rhetorically....it does not appear the engineers wanted people to actually look at the oil...probably smart as most people don't and better to just have a computer check...
