Tech Help...
Old Mar 10, 2012 | 11:26 AM
Evolved8's Avatar
AMG Fam
Tech Help...
Search gave me nothing helpful...
My drivers fog light is out, Cant seem to find a fuse anywhere under the hood, in cabin or in the trunk for it. Not receiving 12v at the plug when the fogs are on. Can someone help?!!
Thanks guys!!
Old Mar 11, 2012 | 12:19 AM
Evolved8's Avatar
AMG Fam
hjow is there 100 plus views and noone knows help me out brothas!!
Old Mar 11, 2012 | 12:43 AM
black06c230's Avatar
mgLipGD
there is no "fuse" per se to pull and check. It is part of the elec. fuse that runs/monitors the lighting system. so i would check the wires go to the light its self.
I could be wrong but when I checked on my C230 that is what I think I remember. I couldn't never even figure what fuse controlled the lighting system.
Old Mar 11, 2012 | 12:46 AM
mgLipGD
ignore me
Old Mar 11, 2012 | 06:33 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
check the light control module that may be going bad
Old Mar 11, 2012 | 07:16 AM
Roverron's Avatar
ML63
IF the light was out or bulb disconnected you must reset the warning message to get power back ot the light and a key cycle. if the circuit doesn't see resistance then power will not go out to the light. there is an internal bypass like a circuit breaker inside that watches for proper resistance.
So to fix it working bulb in socket
reset warning light
cycle key to ignition on all the lights on but not started
then turn light on on
Old Mar 11, 2012 | 02:21 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Chances are the connectors on the pigtail have corroded. I've had to replace both of mine. Just unplug the connector from the rear of the fog light and then unplug the pigtail from the harness. There should be a white tag on the pigtail with the special AMG part number. They're about $12 apiece. Make sure the blade connectors on the bulbs are clean and shiny. If not, clean them or just replace the bulbs.
