Hate to be a Toadster...Trunk Problem?
Old Mar 15, 2012 | 07:35 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
The trunk would open all the way and now stops working. Only opens up a little. The motor works since I push the close button and it sucks in shut also....any ideas?
Old Mar 15, 2012 | 07:40 PM
Toadster's Avatar
2005 E55 AMG
LOL mine works!
Old Mar 15, 2012 | 07:54 PM
gdestiny's Avatar
2007 E63
Check trunk limiter in settings. It might be on.
Old Mar 15, 2012 | 07:55 PM
Nasty50-Five's Avatar
05 E55 AMG
Dj, this happened on my car 2 or 3 times already. I swear my car has a mind of its own, sometimes things work and sometimes things dont usually the trunk starts working after a few hours, I have no explanation.
Old Mar 15, 2012 | 08:01 PM
djrabbi's Avatar
Mine was working but I closed it manually and stopped working. Maybe disconnect the battery will sync it again?
Old Mar 15, 2012 | 10:33 PM
cahiil55k's Avatar
Mine did this before but it went away on its own. I like to think I helped to fix it because I started pressing the trunk release button repeatedly (making the trunk open a little, then pause, then open, then pause, etc).
Old Mar 15, 2012 | 10:47 PM
vioilio's Avatar
2003 E55 AMG
I think this function is temperature dependent. If it is cold it will not open all the way and just a little bit.
Old Mar 16, 2012 | 12:36 AM
xpl0sive's Avatar
CLS55 AMG
use search. theres a wire that breaks in the harness going to the closer button, you simply need to repair the wire.
Old Mar 16, 2012 | 03:02 AM
harjothundal's Avatar
05 e55
It is indeed the wire on the left side that gets sliced.. This is why it works partly, once the harness moves to a certain position the wire no longer makes contact and the power is lost to the system, stopped the function.
I fixed mine a few months back and took lots of pics.. Let me see if I can find the pix and I'll post it as a DIY.. You can do it in less than 1 hour..
Old Mar 20, 2012 | 12:11 PM
djrabbi's Avatar
I did search but everything else wasn't for the motor, but will check it out.
Yes they will be awesome! I remember I did this on my E-Class and had 4-5 wires sliced lol
Old Mar 20, 2012 | 12:16 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
that would be awesome....just started to happen to me
Old Mar 20, 2012 | 01:27 PM
saleen01's Avatar
2004 E55
this!....has happened 3 times to me...annoying
