BOOST gauge
Old Apr 13, 2012 | 07:20 PM
GRAFH's Avatar
2005 E55 AMG
BOOST gauge
Has anyone installed one before? I know they are typically for turbo cars but I know some of you are running higher boost than stock.
Old Apr 13, 2012 | 09:25 PM
jmb614's Avatar
E55 AMG
Yes.
Old Apr 15, 2012 | 10:38 AM
FASN8N's Avatar
CTSV/6sp Grocery Getter
Originally Posted by jmb614
Yes.
Wow, what a helpful reply! Any details?
Old Apr 16, 2012 | 08:44 AM
jmb614's Avatar
E55 AMG
Sure When I purchased a zeitronix zt2 wideband and dashdaq setup I also got a MAP sensor. I had it installed on the passenger side surge tank and ran the wiring through the firewall to the ZT2 control unit which then feeds the dashdaq. I datalog quite a bit, so I wanted to get as many parameters directly from the engine or ECU instead of going through the painfully slow OBD2 port.
Old Apr 16, 2012 | 10:31 AM
zneB-sedecreM's Avatar
MB; 55KCL AMG, SL550 SLS AMG G500 Cabrio 280SL ML350 CLS550 ML500 E55 AMG CL500 S600 SLK32 AMG
Any pics of just the boost gauge installed so we can get an idea of what one looks like in AMG?
Old Apr 16, 2012 | 10:37 AM
jmb614's Avatar
E55 AMG
The gauge or the sensor? The gauge is displayed on a Dashdaq XL, and is configurable. I don't have a pic of the installed sensor atm, if you would like I can post a pic once I get the car back from my fabricator.
Old Apr 16, 2012 | 11:23 AM
GRAFH's Avatar
2005 E55 AMG
I'm talking about a boost gauge that senses vacuum. I want to know where you tapped the supercharger for vacuum.
Old Apr 16, 2012 | 01:58 PM
jmb614's Avatar
E55 AMG
All apologies, I confused the two. I don't have a boost gauge installed. Though I believe boost can be logged through the OBD2 port. Or if you datalog with a MAP sensor subtract 14.7.
Old Apr 16, 2012 | 02:17 PM
GRAFH's Avatar
2005 E55 AMG
Yeah monitoring boost via an electronic signal is not the best way. A boost gauge ported to a vacuum source on the supercharger is the best way.
Old Apr 16, 2012 | 08:20 PM
320 dreamer's Avatar
2003 porsche 996 turbo
you can easily tap the mani for vacuum boost
Old Apr 17, 2012 | 02:11 PM
GRAFH's Avatar
2005 E55 AMG
Anyone with an e55 amg know which port to use? Their are a few unused ones on our motor.
Old Apr 17, 2012 | 02:15 PM
sneakyneon's Avatar
Bicycle
There are no unused ports that see boost on the 55K motor. You must drill and tap POST SC otherwise your reading vacuum only
