Red battery/visit workshop
Old Apr 18, 2012 | 11:10 PM
Forrest Gump 9's Avatar
shrimp boat
What can cause the red screen with the battery sign and visit workshop display?
I thought it was the battery, switched both the front and rear out with brand new batteries but the red display is still there.
Old Apr 18, 2012 | 11:16 PM
berti_00's Avatar
2016 Cls63s AMG
your Voltage regulator is bad... its a 60 dollar part and is right on the alternator
Old Apr 18, 2012 | 11:19 PM
Jimshorts's Avatar
'05 SL65, '13 FX4 Eco
Wasn't the voltage regulator for me... had to replace the whole alternator.
Old Apr 18, 2012 | 11:20 PM
shrimp boat
Thank you for the quick reply. I was afraid the alternator, but I can live with the voltage regulator.
Old Apr 18, 2012 | 11:30 PM
shrimp boat
The weird thing is that it's been like this for the last three months or so. The car has been fine other wise. Oh well, I'll try the voltage regulator first and see what happen.
Old Apr 18, 2012 | 11:41 PM
baldmike73's Avatar
mine was the secondary battery -
Old Apr 19, 2012 | 12:45 AM
Roverron's Avatar
ML63
hey Forrest i have one for cheap like $50 Bosch original it was in the classified section.
Old Apr 19, 2012 | 01:21 PM
0-60inAMG's Avatar
2004 MB E55 AMG
it was the secondary battery on mine as well, just picked up the exact fit replacement battery at Walmart for about $85, the stealer wanted over $300
Old Apr 19, 2012 | 01:42 PM
cahiil55k's Avatar
Just 2 weeks ago I had to replace my secondary battery because of the same red warning described in this thread. It was an $80 battery at Pep Boys. Make sure you properly prep and charge the battery before installing it. I had to trickle charge mine for 8 hours before putting it in.
Old Apr 19, 2012 | 03:23 PM
bghark's Avatar
2006 E55 AMG
+1, had to put in new alt. Not a bad job but do it from underneath. At least it was for me. A one hour job.
Old Apr 19, 2012 | 04:22 PM
AWOL's Avatar
e55
It wasnt the voltage regulator for me either.
I still get this message but have yet to swap out the alt
Old Apr 19, 2012 | 04:41 PM
blackbenzz's Avatar
haters crazy
Also check your ground strap but yea most likely alternator
Old Apr 19, 2012 | 05:06 PM
berti_00's Avatar
2016 Cls63s AMG
our alternators i hear are super solid and almost never fail but than again you never know
Old Apr 19, 2012 | 05:14 PM
AWOL's Avatar
e55
This would make the second time mine has failed, fwiw
Old Apr 20, 2012 | 12:48 AM
backdoc7's Avatar
C300, Viper RT/10, E55
I got into the car today and no A/C.. then got the "Battery Protection" conven. features turned off warning... was told by the indy over the phone it's most likely the aux battery so I replaced it. That wasn't it and I got the red "BRAKE" screen and my brakes actually pretty much went out about a mile from home on my drive home.. as I was pulling over on the freeway the red light went off and I had brakes again so I got her home. I also got the "low voltage" screen on the command screen. Might just change out the rear battery and go from there but from those symptoms, especially the "low voltage" on the command does that mean voltage reg or alt? Thanks.
Old Apr 20, 2012 | 11:17 AM
Roverron's Avatar
ML63
can you get a volt meter and see if its charging at idle. should be over 12vdc. I know I thought i had an issue with my alt and volt reg, but it was only that i don't drive the car long enough to charged the battery after working on it. my drive to work is less than 10 mins so it would not get a full charge. i bought a charger and charged both batteries up and not problem since then. if you need a voltage reg i can sell you mine its a BNIB Bosch. $60 with shipping.
Old Apr 20, 2012 | 11:51 AM
backdoc7's Avatar
Thanks.. i might need that volt reg.. I trickle charged the rear battery over night and started the car this morning.. all warnings were gone. That might mean the alt isn't charging the battery or maybe it just took a slight charge overnight, enough to make the warnings go away.. I will test with a volt meter and go from there. Thanks!
Old Apr 22, 2012 | 04:16 PM
backdoc7's Avatar
OK, so I used my torque program to check voltage both with the car in idle and at 2,000 plus rpm's and it's always 11.8-12.1 volts. I guess I'm not charging hence the "battery protection" mode. So before I replace the rear battery, I guess I have to figure out if it's the volt meter or alternator. Any way to check this at home? Might just start with a volt meter and go from there since the rear battery seemed like it took a charge with the over night trickle charger.. any advise is appreciated. Thx!
