What is a normal IAT value for a bone stock E55?
Old 05-01-2012, 02:10 AM
bleucamaro's Avatar
'06 E55 AMG
Not really new here, but don't really post much, as I normally just read. I am new to owning an E55. Its an '06, bone stock, 38k miles. Out of curiousity I put my LM-2 data logger on it and with an ambient air temperature around 60°F it read an intake temperature of 119°F. On the freeway cruising around 75mph, it was reading in the high 120's. I made a 3rd gear pull and the temp peaked at 158°F, then took about 5 minutes to cool back to 140°F.
So far I've searched for "normal intake temp" and "normal IAT" and have found values for modded cars, but nothing for a stock car.
What is a normal Intake Air Temperature for a stock E55?
I've also read that the ECU controls the intercooler pump. What temperature is it programmed to turn on at? Also is ECU using a PID or PWM control to try to hold the intake air at a given temp, or does it just trigger a relay to start the pump?
Old 05-01-2012, 02:23 AM
amg guy's Avatar
2019 GLE 63 S Coupe 2020 E 63 S
About 20 degrees above ambient is typical. From the numbers you are seeing I'm betting that your IC pump is toast. I have a 175 pulley and newer bosch pump and have never seen it get that high.
Old 05-01-2012, 04:58 AM
theeddie's Avatar
e55 w/LET TUNE Drinks: vodka STRAIGHT Wheels: 19" HRE 547r Mods:FF headers ASP Pulley
your recovery time should be under 20 sec while moving. your pump is hosed
Old 05-01-2012, 07:52 AM
vioilio's Avatar
2003 E55 AMG
Time for a new pump. You have plenty of options like CM30,CM90 or Meziere pumps.
Old 05-01-2012, 08:10 AM
GT-ER's Avatar
2005 E55 AMG
pump = dead
Old 05-01-2012, 09:00 AM
cij911's Avatar
one car at a time
get the new MB pump (replacement part)...Bosch 010....plug and play and outflows the CM30
Old 05-01-2012, 09:08 AM
Hulk's Avatar
A Merc
^^^^^^ yes it's a good pump
Quick Reply: What is a normal IAT value for a bone stock E55?
