Please help Check Gas Cap light came on.
2004 W211 E55K, GL550
Hey guys, I have my check gas cap light coming on after i shut the car off the light goes off but after driving for for a few miles light comes back on along with the check engine light on and it stays on. Ive already changed the gas cap with a original one. Im going to check it out tomorrow but i was trying to see if anyone ran into the same issue any help would be greatly appreciated would like to resolve this issue asap thanks in advance. P.S i tried the search button didn't really come up with anything
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
I kept getting the check gas cap light, so I bought a new gas cap. Still got the message. Took it to the dealer and they said I had a bad charcoal canister. So they replaced it, all under warranty. Haven't had the message since. I hope that helps.
Thank you sir ill give that a look tomorrow. I googled it and seen a few other people who also had a similar issue. Anyone else???
'05 SL65, '13 FX4 Eco
I had the same problem on my car, really pissed me off. Took it into the shop about 4 different times and they continued to charge me to diagnose it each time I went in. they were wrong every time and never found the fix.
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
I believe what fixed his car was a charcoal canister shutoff valve. I'm sure he'll chime in. Also if the new valve requires a adaptor harness (some do) check the wiring of the harness. A batch of them were wired incorrectly from mb and it swapped the two wires.
the wire colors would stay in the same pins if that makes sence.
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Yes Ion is correct charcoal canister/gas vent valve canister i guess u can call it either/or. Very very simple fix its right next to the driver side head light i belive 2 vaccum hoses & a electrical connecter. Part cost me i belive anywhere from 60 to 80 bucks. Put it in like 5 mins reset my ecu with my scanner and problem solved. But before u do that check your evap hoses that go to the canister valve they may be broken or disconnected. Hit me up if you need anything else.
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Scoobywrx (08-14-2017)
