Injector Information Help
After having done some homework on Injectors, I have come up with some of the following information.
A1550780049 is the SLR injector part number from mercedes and the Bosch P/N for the same plug is 0-280-156-148.
The SLR Injectors are 6 hole spray and blue in color as opposed to the E55 being 4 hole and black in color.
Standard e55 are 3.09 per gram per minute at 3 bar
(412cc/min @ 3bars that means 39.23Lb/hour)
SLR 3.39 per gram at 3 bar
One thing I could not get much information on was the spec of the 2006 E55 Injectors which are supposed to have the same flow rating as the SLR Injectors (3.39 gram at 3 bar) but a 4 hole not 6.
Anyone with additional info on the 2006 Injectors??
Is it as important for the 2006 E55's to upgrade injectors considering they flow better than the rest of the years?
I have all the typical stuff. 180 pulley, headers, 82mm tb, no cats, and a custom y-pipe.
