Getting heads done..... Need opinions
1. WHY would you check EVERY spring pressure in an engine reving below 7K? Sure it doesn't hurt, but it is OVERKILL, IMHO. New springs really only needed checked on a tension meter, as the installed height will NOT vary that much. In general.
2. Why would you adjust everyone as small differences make NO difference in low revving engines? AKA there is NO performance to be had here if they are out 10-20 pounds per spring, which the odds are they will not be.
I will agree that you guys are in uncharted waters with MB heads. But a head is a head to a engine shop. The flow bench tells all the results, and couldn't careless wether it was a GM, Ford, MB, or Veryon head on it.
PS: My last Ford head, larger valves, cut exhaust out, remove EGR bump, flow test, 5 angle, new valves, seats, guides, seals, was right around $1K.
Just food for thought here. carry on
First thing, they were 2 valve 5.0 heads, so cost for them IS cheap I will admit. But also AFR sells CNC heads for this pig for only $1700 a pair.
As far as you get what you pay for, me and you BOTH know this is NOT a true statement all the time. You get what you ask for, and how much you know plays a HUGE role in that amount. If you roll up in a E55 and say, I wont as much as you can give me, they will answer no problem 5K+. Now if you roll up and say, I would like them flow benched, 5 angle VJ, larger valves by .1" and by the way remove the EGR bump, they will know what you are talking about, and the price comes down.
In any case, good luck to all, and learn a little BEFORE you approach ANY engine shop, IMHO.
PS: Spring bind is a VERY easy calculated number, and I REALLY doubt you were close to it. AS after all, NO one builds a radicle cam for our engines. Some have an extra .040-.070 lift, which really doesn't mean a hill of beans in the real world, just saying.
I hope you get out there and break some more records
Best thing about this approach is that once a head has been scanned and optimised the same head can be done again as a plug and play... They claim 18% more flow and I was looking at having it done but at $3250 it's a big ask .... And have not jumped ...
