Sub-woofer question
Old Jun 20, 2012 | 04:03 PM
03'55AMG's Avatar
AMG
Sub-woofer question
I have done a lot of searching and have a good idea on how tricky a sub swap is, but still have a few questions.
-As far as the car throwing the battery light with an aftermarket amp, would a cap help with this issue even if im only planning on running 3-400 watts RMS? Im looking at a 10" sub that will handle 550 RMS and 1200 peak, and an amp that will be a bit under those ratings (~400 rms/ 1000 peak).
-With the stock sub in place and a single 10" in the trunk, will any of this bass even get into the cabin? I am trying to avoid ripping up the rear shelf, and plan on using a ported box, instead of an infinite baffle setup.
Also, would sound deadening be required to avoid a rattle?
any advice would be helpful
Old Jun 20, 2012 | 05:08 PM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
I have at least that much of an amp without issues. I removed my factory sub and built a box that bolts up to the bottom of the rear shelf firing through the factory location. My thread is around here somewhere. I'll find it when I get home in a day or so. Search here and the planet. I remember csmungi having a thread on his set-up.
Old Jun 20, 2012 | 05:59 PM
03'55AMG's Avatar
AMG
Did you have any issues as far as rattle? and does your setup have a capacitor?
Old Jun 20, 2012 | 07:27 PM
It rattles when I really put the juice to it but not under normal operation. No capacitor.
Old Jun 20, 2012 | 10:06 PM
03'55AMG's Avatar
AMG
Good. I figured it would be SUPER easy, battery is within a foot of where I'd mount the amp, audio and signal wires are all within a foot or two also. Hopefully going to be a super easy install.
Oh, As far as the ground for the amp goes, Would it be best to ground directly to the battery or to the chassis?
Old Jun 20, 2012 | 10:33 PM
Battery ground goes straight to chassis. 6 to one; half dozen to another.
