**Fabtech-Performance**Product Release and Updates **Official Thread**
Former Vendor of MBWorld
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
**ATTENTION MB WOLRD MEMBERS**We will be compiling all of our products and services into one Official Thread, Where you can view what we have to offer and ask any questions you may have. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
![](http://i88.photobucket.com/albums/k198/projectturboex/T-Shirt-Back.jpg)
UPDATE!!!! FOLLOW US IN THE NEW SUB-FORUM WE HAVE BEEN WORKIONG WITH SITE ADMIN ON TO MAKE IT EASER FOR EVERYONE TO VIEW PRODUCTS AND UPDATES WITHOUT HAVING TO SCROLL ALL AROUND THE FORUM!!![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
![](http://i88.photobucket.com/albums/k198/projectturboex/MBWORLD1.jpg)
NEW PRODUCTS ADDED!!!! https://mbworld.org/forums/vendor-announcements-161/
Contact:
E: Steve@fabtech-performance.com
P: 614-638-8732
W: WWW.FABTECH-PERFORMANCE.COM
OUR PRODUCT LINEUP IS CONSTINTLY CHANGING AND NEW PRODUCTS ARE BEING ADDED WEEKLY SO PLEASE VIEW OUR ENTIRE THREAD AND VISIT US ONLINE AT WWW.FABTECH-PERFORMANCE.COM FOR THE MOST UP TO DATE PRODUCT INFO![word](https://mbworld.org/forums/images/smilies/werd.gif)
FUEL DELIVERY PRODUCTS
Fabtech-Performance Black anodized An Fittings/Braided hose Builder Kits
Info: We Will meet or beat ANY price on AN line and in stock Fittings from JEGS or SUMMIT racing!! We stock -6 -8 -10 Black braided AN hose and Misc Fittings. We also carry In line Anodized Fuel filters and Pumps![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
![](http://i88.photobucket.com/albums/k198/projectturboex/photo1-1.jpg)
![](http://i88.photobucket.com/albums/k198/projectturboex/photo-3.jpg)
Fabtech-Performance Looped Fuel Systems
Info: Tired of reading about all the BLOWN ENGINE HORROR STORIES? The fact is the M113k Fuel system STARVES Cylinder NUMBER 8, causing detonation thus killing your engine!! These Fuel systems are the only ones on the market that offer custom CNC machines Stainlss Steel Fittings instead of Mild steel fittings that rust and need coated!! They are percision tig welded and properly Backpurged with argon gas to ensure a PERFECT WELD on a Genuine OEM MB fuel rail.
System Includes:
-MB Fuel Rail
-Stainless 300 PSI rated Loop with Black anodized tight radius fittings
-Custom CNC Machined Weld fittings
-FTP 6 Nozzle spray pattern Injectors
-FTP Adapter Clips for No hassle install
$499.95 Rail only /// $999.95 Complete system!!!![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
![](http://i88.photobucket.com/albums/k198/projectturboex/FTPRail2.jpg)
![](http://i88.photobucket.com/albums/k198/projectturboex/bbae7a52.jpg)
COOLING PRODUCTS
Fabtech-Performance Dual Pass Heatexchanger
Info: Beat the Summer heat, end your S/C shutoff and purchase the only H/E on the market that is a DIRECT bolt on to a W211 E55 chassis for THE BEST PRICE!!(Factory location mounting points used)
Our Dual pass H/E has a LIFETIME Warranty Against weld Defects, and is 2x larger than stock.
$339.95 Aluminum Finish /// 369.95 High Temp Ceramic![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
![](http://i88.photobucket.com/albums/k198/projectturboex/photo45.jpg)
![](http://i88.photobucket.com/albums/k198/projectturboex/FTPHE3.jpg)
![](http://i88.photobucket.com/albums/k198/projectturboex/FTPHE2.jpg)
Fabtech-Performance Engine Bay Mounted I/C Tank
Info: Wanting to split your system, Run cooler IAT's and still be able to Ice down for a track run?? The FTP Engine bay mounted tank Delivers all of that to the table with a Very easy install, (Guide Included) It features a 2 Gallon tank, Easy Twist off cap all lines and all lines and fittings needed!! LIFETIME WARRANTY ON THE I/C TANK!!
$599.95
![](http://i88.photobucket.com/albums/k198/projectturboex/BayTank3-1.jpg)
![](http://i88.photobucket.com/albums/k198/projectturboex/BayTank1.jpg)
![](http://i88.photobucket.com/albums/k198/projectturboex/bayTank2.jpg)
Fabtech-Performance Trunk mounted S/C Inter-cooler tank
Info: This Tank successfully has our IAT's no more than 10 DEG above ambient while driving. Hit the pedal on a 90 degree day and max IAT's we are seeing 136 and recover back to normal in less than 25 seconds!! ICE The tank down and run up to 20 DEG BELOW ambient for a few pulls and discover the difference!!
(Results will vary based upon your cooling setup, Mods Tune DA climate etc.)
[B][COLOR="Red"]$529.95
![](http://i88.photobucket.com/albums/k198/projectturboex/ICTank2.jpg)
![](http://i88.photobucket.com/albums/k198/projectturboex/ICTank1.jpg)
LIGHTING
Fabtech-Performance DRL Package E63 Bumper ONLY (55k Coming)
Tired of looking for the near impossible Wald DRL package that is over $400 dollars? PROBLEM SOLVED for a fraction of the price.
Info: Our kit uses ABS Plastic Custom fit Grilles, 8 filament LED's and is a DIRECT replacement of the Factory Fogs!! NO ERRORS 30 minute install
$99.95 (SPONSOR SPECIAL) 2 SPOTS LEFT AT $99.95 PRICE/// Add $49 for the double wide leds![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
![](http://i88.photobucket.com/albums/k198/projectturboex/f15f3c2d.jpg)
![](http://i88.photobucket.com/albums/k198/projectturboex/08647a14.jpg)
ENGINE PERFORMANCE
Fabtech-Performance 3'' Beast Tubes
Info:These tubes will help induct air into your engine faster than ever before!! Constructed of 3'' Mandrel bent Aircraft grade 6061 Aluminum with custom 3 ply silicone couplers to mate to your factory plastic air scoops.
$199.95 (SPONSOR SPECIAL PRICE 1 SPOT LEFT) /// Ceramic coating///Paint Match///Black heat wrap extra
![](http://i88.photobucket.com/albums/k198/projectturboex/5a1d7a3a.jpg)
![](http://i88.photobucket.com/albums/k198/projectturboex/577323ab.jpg)
FACTORY INTAKE TUBE EEEKKKKK!!
![](http://i88.photobucket.com/albums/k198/projectturboex/51e5de50.jpg)
Fabtech-Performance Oil/Air Separator
Info: Ever wonder what is passing into your Throttle body and Surge tanks? Because its not just AIR!! The FTP Oil catch can is ideal for STOCK or modified Mercedes engines. They Help relive oil in the intake system from gumming up engine components and helps with crankcase pressure. Within a few thousand miles pop your catch can off to see the oil you stopped from going into the The engine's top end and gumming up the T/B, Surge tanks ETC.
Features:
-100% Bolt on No modifications Required
-All lines cut to Size!!
-Billet CNC 6061 Aircraft grade Aluminum
-O ringed removable twist off bottom
-Strainer built in internally
-Aluminum mounting bracket
$129.95// Instructions and everything needed for install
![](http://i88.photobucket.com/albums/k198/projectturboex/CatchCan.jpg)
Fabtech-Performance 82MM T/B Kit
Info:All MB parts are utilized for these kits for optimal Performance, OEM Fitment, no CEL's and A Superior product to help Motor your AMG faster than it ever has before!!
Benefits:
-Up to +35 whp gains
-Works in conjunction with your stock Airbox
-Increases TQ
-NO CHECK ENGINE LIGHT
-No messing around with audi, Porsche throttle bodies
-No pin swapping needed
-Direct bolt plug and play!
-Will Fit C/F Air boxes with Little modification
Features:
-ALL OEM MB COMPONENTS
-Install guide
-MB 82mm thottle body
-MB 80mm Y pipe
-FTP modified sc inlet for flush mount INSTALL
(no adapter plate needed!!) and bore matched to the mb 82mm TB LOOKS STOCK INSTALLED!!
-TPS harness
- All necessary hardware (bolts and clamps)
MB World Price$1299.95
![](http://i88.photobucket.com/albums/k198/projectturboex/FTP1.jpg)
MB T/B and S/C inlet are Reconditioned but tested and in perfect working order. Everything else is NEW OEM MB parts
Fabtech-Performance Drag Pack
Info:Our Drag package successfully puts your traction problems to rest! This package is known to cut 1.5x 60ft's and it will motor you down the track faster than you ever have before. We are glad to release the first Bolt on and Go Slick Skinny package available for MB, You can outfit this package complete with Tires and be out the door for less $$ than a set of high dollar drags, AND THAT'S THE WHEELS ALONE!!
2 OEM CLK Aluminum 16 inch wheels (Lightest wheels to date for our cars on the market)
2 Fabtech-Performance Custom Machined 18'' AMG Replica Skinny's (6 inches Wide) (Weight with tires 41.9 LBS each same as CCWS!)
2 Custom machined billet aluminum wheel adapters with bolts
Wheels Powder coated in any color of your choice
MB Center Caps Paint matched
$1299.95/// Different style wheels EXTRA
![](http://i88.photobucket.com/albums/k198/projectturboex/photo2.jpg)
![](http://i88.photobucket.com/albums/k198/projectturboex/photo-2.jpg)
Tires Pictured NOT included!
(Please allow 1.5 weeks for completion As labor for the Skinny's is extremely intensive!!)
Contact:
P: 614-638-8732
System Includes:
-MB Fuel Rail
COOLING PRODUCTS
$599.95
LIGHTING
ENGINE PERFORMANCE
Features:
Benefits:
-Increases TQ
Features:
-Install guide
-MB 80mm Y pipe
-TPS harness
More Pictures and Info Coming ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
![](http://i88.photobucket.com/albums/k198/projectturboex/AMGGauges.jpg)
UPDATE: WE ARE NOW A DASHDAQ DEALER!!!
CLICK THE LINK BELOW FOR ALL THE INFO AND BEST PRICES PERIOD!!
https://mbworld.org/forums/vendor-an...ml#post5290712
FABTECH-PERFORMANCE STAINLESS EXHAUST SYSTEM
https://mbworld.org/forums/e55-amg-w...ems-click.html
![](http://i88.photobucket.com/albums/k198/projectturboex/FTP-4.jpg)
Thanks Elliot!! now if i can just convice this certain 10sec bound E55 he needs some Fabtech love ![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
[/quote]
I think I pretty much have everything already
. I'm just missing the front skinnies and the catch can. Maybe we can work something out
. I would love to support your company.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
05 White Pano E55, Cadillac CTS-V
Come on now Elliot, salt isn't messing up the pump. It is made for boats as a bilge pump to pump the salt water out haha ![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Sorry I had to![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
But then again, maybe the smaller pump up front could have a problem? Hmmm, probably not either way though.
Sorry I had to
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Now these are the kinds of prices I feel we should be seeing for these items. No "Mercedes Tax" here folks. Soon as I'm done screwing around with other projects and dig into the AMG I'll surely be buying some parts from FTP. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Someone should throw some salt and ice in their tank and see where the IATs go. Could be on to something here.... Esp with everyone trying to beat their best times and or go for 9s...![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
1 Post
CLS 55 AMG, FX45, F-350, Top Secret Widebody Supra (Sold) and other vehicles on another Planet
Steve makes some amazing products! I am proud to say that I am a satisfied FTP customer!
BTW Steve..............You already know which product I'm waiting for from you......![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Yea, forgot about Dry ices ability to make quite the bomb under pressure. So salt and water would be the only safe way to have super cooled liquid with making a bomb in the trunk?
Definitely no to the dry ice. Dry ice + water in an enclosed system does this:
http://www.youtube.com/watch?v=QWPzeZOifzk
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
Soon My friend soon. We just need a doner car to speed the process up
Thanks as always, This is why we are here!!
Pmed
With the rear tank you can add dry ice mixed with ice (obviously you leave the top off) between runs and drop water temps down as much as 60 degrees in about 35min
https://mbworld.org/forums/5095234-post1.html
