For better acceleration and Performance 18" or 19" light weight wheels ~which one??
08 E63 AMG
Hi ~ guys ~
I'm trying to get rid of my stock 18 inch wheels and get my self a set of
forged wheels.
My most concern is that which size I should go for ~
I was under the impression smaller wheels provide better acceleration off the
line and does give you couple pounds of weight savings as well.
However I DO like the look of 19 inch wheels.
Which size shall I go for ????????????
they are both forged wheels 18 inch and 19inch.
18" 8.5 = 19.5 lbs = front
18" 9.5 = 21.05 lbs = rear
18" 10.5= 21.25 lbs = rear ( Will 10.5J fit on the rear?????
19" 8.5 = 21.4 lbs = front
19" 9.5 = 22.5 lbs = rear
19" 10.5 = 22.4 lbs = rear
forged wheels.
Looks like your only concerns are acceleration and performance (or at least thats what you posted).. I think the answer should be pretty clear (18s)..
08 E63 AMG
Stock weights aprx 7lbs more . In this case even 19 inches are bigger but since
its lighter will it be better than stock wheels??
Hey thank you for your reply . 19 would look def better right ???
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
what can you say about above question that I asked to "AMGpilot"
2008 E63, KTM990, 2012 CLS63, 1972 W108 280SE 4.5
Anyhow this and weight reduction due to forged wheels are really minimum to represent any advantage with stock car.
a Rivera...via a Custom 24, Strat and Les Paul
Hi ~ guys ~
forged wheels.
forged wheels.
I moved to 20x9 fronts and 20x10.5 rears and tbh you can tell no diference on the street with regards to excelaration or braking due to extra weight . I think kerb side is around 3545 lb and the seat of pants dyno would not notice a 1% increase .
Handling is way way improved and I guess brake cooling so it's been plus plus all the way for me .
Marc
Marc
Just put my fronts on the scales original AMG wheels and tyres are 52 lb and the brabus 20x9 with tyres are are 56 lb . So increase over 4 wheels and tyres I dout is more than 20lb.
You may notice on a drag strip a slight decrease in execration due to extra weight ?
Marc
Marc
08 E63 AMG
Marc
Marc
wheels with no problem?? What size rear tire do you have ?? 295 ??305 ??
Hi I'm running 285 25 20 with no problem and 255 30 20 fronts but now changing to 265 30 20 fronts . My wheels were original factory fit on a brabus k8 and 10.5 fit with no issues at all .
Regards
Marc
Regards
Marc
