E63 Transmission fluid...How much do I need..
Old Jul 5, 2012 | 01:20 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
Had my fluid change about 1500 miles ago and the pan is leaking.
I would like drop the pan new gasket and just add back the fluid in the pan.
Anyone know how much fluid I need to do this job..07 E63
I was told to use back the fluid I took out since it was new fluid. I dont want to use back that fluid just in case of comtimination.
I will be getting dealer fluid.
Thanks Sunil...
Old Jul 5, 2012 | 01:23 PM
desired_speeds's Avatar
2007 SL55 AMG
you need SDS to measure oil level by temperature.
Old Jul 5, 2012 | 03:31 PM
sunil517's Avatar
Speed...Those wheels are pretty nice
I have CLS 19s
Old Jul 5, 2012 | 08:22 PM
Shifter's Avatar
E55, SL63, ML550
Dropping the pan and filter change you add 5 liters and then let it run out (overflow) to correct temp. (100*f) If your not changing the filter maybe a smidgen less.
