asp pulley wobble
Rating: Thread Rating: 27 votes, 4.85 average.
Old Sep 17, 2012 | 08:47 PM
  #51
novae500's Avatar
W211
how was your belt after you beat that lambo??? are you planning on replacing the pulley since it may be the cause of throwing so many belts?
Old Sep 17, 2012 | 09:09 PM
  #52
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
The belt was fine after racing the Lambo I run my car pretty hard so it doesn't fall off every time I run it hard but when it does fall off 90% of the time it is after a hard run.
And yes definitely thinking of changing out the pulley waiting to hear back from the manufacturer... In all likeliness if I keep the car I will probably run a stock pulley or 168 pulley with the new weistec blower once figures come out and some cars run them for more than a few weeks
Old Oct 2, 2012 | 10:57 PM
  #53
gaspam's Avatar
awesome, another belt bites the dust.... this time it didnt just fall off like it usually does, it just exploded into a million shreds, wrapped around the accessory belt and took a nick out of it...
now i will need to replace my accessory belt before that nick turns into a snapped belt and overheated car on side of road... lol i love this !
Old Oct 2, 2012 | 10:59 PM
  #54
gaspam's Avatar
btw does anyone have a spare stock pulley they could sell me?
i need to put one on while i send this 172M pulley in for warranty as the manufacturer said they will warranty it and send me a new one.
Old Oct 2, 2012 | 11:08 PM
  #55
Hulk's Avatar
A Merc
If your in Miami ask RBJ
Old Oct 2, 2012 | 11:13 PM
  #56
gaspam's Avatar
at moment i am in nashville since i am on contract up here but come back to miami at least once per month.
but if elliot has one, i'll buy it!
Old Oct 2, 2012 | 11:18 PM
  #57
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
That sucks man, best of luck to you while you go through this. Curious, is the outer lips not tall enough?
Old Oct 2, 2012 | 11:22 PM
  #58
gaspam's Avatar
thanks bro!
and thats what is seems like... seems like that the belt is able to either jump ontop of the pulley lip and split itself in half and then proceed to tear itself up, or its able to just completely jump off the pulley and over the lip (in those cases i can just put the belt back on)
Old Oct 4, 2012 | 08:35 PM
  #59
gaspam's Avatar
while waiting to find a stock crank pulley, i decided to order a different belt size as I saw a dayco 5080510 which is effective length of about 51 inches so about .4 inches smaller than the gates 51.4 in that is recommended for the 172m pulley...
i was able to get it to fit so will see if that keeps belt from hopping off but its probably gonna just shred...
since the manufature of the pulley is going to warranty it, i might just go stock crank pulley and buy one of the s/c pulley for the meantime and sell the 172M they send me since in all likeliness when the whipple s/c come out i will prob buy one and dont want to run a 172M pulley in combo with the whipple
Old Oct 5, 2012 | 08:56 AM
  #60
cij911's Avatar
one car at a time
Sounds like you have a tensioner problem....There was another post just recently made, where the guy had the same issue you are having only to discover the tensioner had been installed incorrectly.
"Mods do not necessarily cause issues as much as they reveal them; Case in point I installed a new EC pulley and tune (Thanks Jerry) and immediately began shredding belts. Upon investigation I discovered that a previous owner replaced just the pulley on my tensioner and apparently installed it backwards. The original RPM and torque never revealed the issue. Only upon the mod did the belt find the edge of the pulley and cut itself."
Update : Sorry I just looked at your first few posts...I don't believe it is your crank pulley, but have you had it spec'd to see if it is true ? My guess is this is a bad tensioner issue ( I know you replaced, but I don't know with what)....
Old Oct 5, 2012 | 09:42 AM
  #61
pearlpower's Avatar
He stated earlier he installed a new tensioner. I also stated earlier I had the same exact issue though with a 180mm version, now with a larger welded pulley, I have yet to lose a single belt.
Old Oct 5, 2012 | 10:32 AM
  #62
gaspam's Avatar
yeah i saw that thread but unfortunately its not the tensioner in my case, i wish it was, but i went through and replaced the whole tensioner assembly, ran a different asp tensioner pulley, ran second factory tensioner pulley, etc to no avail.
i have seen at least 3 people with this belt shredding problem on the forum: grandwoodtx, johncy2000 and pearlpower as he stated above and they all have been with the 172m pulley and all seemed to get fixed when they went to the 180m pulley... i am wondering if the 172m is just in a weird size range that cant keep belts on ?
I was thinking of trying out the new belt wrap kit out there but my only hesitation is that if the belts still come of then with the belt wrap kit that brace between two pulleys looks like it could hold the belt into spinning pulleys and get all tangled up, whereas now currently without a belt wrap kit my belt will at least fling itself off and set against the fan shroud outta harms way 9 out of 10 times
You have already rated this thread Rating: Thread Rating: 27 votes, 4.85 average.
