Xenon Ballast Replacement
Needless to say, I replaced the bulb and no joy! So that meant a quick removal of the front bumper cover so I could dismount the headlamp assembly to access the ballast, which is mounted to the bottom of the headlight assembly. The factory procedure is to go for it from underneath by removing the front engine tray, but that meant very limited visibility and pushing wires and hose around to get to the torx fastners, so I opted for the bumper cover removal to have lots of access room and visibility.
The ballast is held in place by three torx screws, and once I replaced it, I had my lights back. I figure I saved a minimum of $500 doing the replacing the ballast myself versus having the dealer do it, having priced a MB ballast off parts.com. Well worth a few hours invested.
