07 E63 Low RPM stutter
2007 E63 AMG
This has happend about 4 times now after a long drive if I am just cruising in town @ very low RPM below 2K I feel a stutter that comes and goes. Check Engine light will come on but it will go away a days or 2 later. My most recent event was last night and it happend on the freeway but I was also cruising below 2K hardly pressing on the gas. If I keep rev's up 2K or a little above stutter goes away quickly. @ idle car idles fine. Car has 83K on it. when this happend last I was on 96 octane gas.
What could this be?
What could this be?
2007 E63 AMG
Wouldn't a miss fire happen @ all RPM's?
It wouldn't ness. Happen at all rpms, when it happens again go read the code, at autozone or something, that will definately tell you what it is, as of right now it's all a guessing game, could also be clogged cats, see how many things it could be? Lol
2007 E63 AMG
intake gaskets
at that mileage you may need your intake gaskets replaced. I had about 62k and would get a CEL after a hard pull or drag racing, read P2187 with a generic scanner. If that's the code you get (i had it checked for free at pepboys) I'd check that out.
pleanty of other thready explaining this, but basically the intake wasn't torqued right from the factory and after time/use the gaskets sometimes developed a leak
2007 E63 AMG
2007 E63 AMG
2007 E63 AMG
There no guarantee cleaning it will work. You need the spray stuff they use to clean electronic components from Radio shack. You got two MAF and they are expensive to replace. There is a way to check if your MAF is bad. Just unplug its and take a test drive around to see if it better. Yes it ok to drive with it unplug. GL
2007 E63 AMG
