HELP! suspension all the way extended
Old Jul 28, 2012 | 04:55 PM
Mr-Uli's Avatar
2001 nogaro s4 s1 (sold), 2001.5 casablanca white s4 s3++ (sold), 2006 e55, 2011 pilot, 2011 edge
car wont stop trying to raise itself. did the washer mod and when we brought the car back down the car tried to raise itself. reverted back to stock setup but the problem wont go away. reset the battery (disconnected both batteries) and it still wont go away. is there a way to purge the bags and get this back down to stock?
Old Jul 28, 2012 | 04:56 PM
03'55AMG's Avatar
AMG
Maybe the compressor relay is stuck? I would pull the relay out and see if it does anything
Old Jul 28, 2012 | 04:58 PM
Mr-Uli's Avatar
where is the compressor relay? wouldnt disconnecting both batteries kinda do the same thing? i feel like the bags are too inflated and wont bleed off pressure. ive never seen the car so high
Old Jul 28, 2012 | 05:01 PM
03'55AMG's Avatar
AMG
If the relay is stuck odds are it wont fix itself by disconnecting batteries. Try looking in the manual to see if it shows where the relay is
Old Jul 28, 2012 | 05:56 PM
gsxrguy's Avatar
e55,cayenne turbo, supra, sti
or you need to connect the height sensors the right way.
Old Jul 28, 2012 | 06:00 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Compressor only provides pressure to the air tank. The Airmatic control unit is raising the car. You should have it checked with an SDS.
Mr-Uli's Avatar
I thought about that but they are in the same exact way they were in before. I can't really see how you can mess that up? If its easy to mess up please tell me and I'll look again.
Old Jul 28, 2012 | 06:06 PM
gsxrguy's Avatar
it is easy to mess up. I guess it is difficult to explain but the the sensor rotates as it goes up and down and you can flipe the arm and cause it rotate in the wrong direction and reverse the signal.
Old Jul 28, 2012 | 06:14 PM
03'55AMG's Avatar
AMG
I almost made that mistake, but wouldn't the car just be high in front if that were the case?
Old Jul 28, 2012 | 06:17 PM
Mr-Uli's Avatar
Could you possibly send me a pic of what yours looks like and I can double check?
I was also wondering why the back is raised as well. When you start the car it says raising car. It isn't until you put it in drive that it says "car too low"
Old Jul 28, 2012 | 06:44 PM
03'55AMG's Avatar
AMG
sounds like bad sensor.
Old Jul 28, 2012 | 07:06 PM
Mr-Uli's Avatar
can anyone shoot me a pic of their sensor orientation before i have it towed to a dealership monday?
Old Jul 28, 2012 | 07:24 PM
Mr-Uli's Avatar
the rear isn't jacked super high like the front. the rear looks like normal high height, its the front that looks like you have 2 fists under the wheel well.
Old Jul 28, 2012 | 08:36 PM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
And this is why you either choose STAR or an ELM.
Old Jul 28, 2012 | 08:42 PM
zneB-sedecreM's Avatar
MB; 55KCL AMG, SL550 SLS AMG G500 Cabrio 280SL ML350 CLS550 ML500 E55 AMG CL500 S600 SLK32 AMG
Links work fine with me so far on multiple cars
Old Jul 28, 2012 | 08:54 PM
Nobody's even seen your car man. That **** is vaporware.
You and your parents might be happy with the lowering links on your cars but they're bad for your suspension, period.
Old Jul 28, 2012 | 09:02 PM
Forrest Gump 9's Avatar
shrimp boat
You mess up the arms on the sensor. Make sure the arms are pointing down when you reconnect the linkages.
Old Jul 29, 2012 | 01:14 AM
03'55AMG's Avatar
AMG
Im next to the car now, Ill snap a few pics of how I did mine.
Old Jul 29, 2012 | 01:38 AM
03'55AMG's Avatar
AMG
crappy pics, hopefully you can read them. Ill post what they say above the actual pic just in case.
The arm circled in hwite MUST be pointed Down. this will cause the car to raise very high if done backwards.
This is just the top nut after about 2000 miles of driving fast.. Lol
This is where the washers should be. Dont use to many or the bolt with not thread all the way onto the stud and will fall off
This is the whole sensor assembly
Old Jul 29, 2012 | 10:43 AM
Mr-Uli's Avatar
That was it! I had the drivers side accidentally flipped. Car is fine now. Thanks so much!!!
Old Jul 29, 2012 | 08:01 PM
03'55AMG's Avatar
AMG
Not a problem. Glad I could help!
