What's the hot ticket in Intercooler pumps?
Old 07-30-2012 | 01:38 AM
AMGPilot's Avatar
2004 E55
the CM30 isn't cutting it
Old 07-30-2012 | 01:42 AM
Toadster's Avatar
2005 E55 AMG
1. Meziere
2. split cooling circuit
3. killer chiller
Old 07-30-2012 | 01:43 AM
AMGPilot's Avatar
2004 E55
Pump only, don't need the other items
Old 07-30-2012 | 01:45 AM
Toadster's Avatar
2005 E55 AMG
what's the rest of your cooling setup?
Old 07-30-2012 | 01:46 AM
AMGPilot's Avatar
2004 E55
Don't worry about it, I'm asking about pumps. and I'm not interested in the Meziere, had one...
Old 07-30-2012 | 03:42 AM
03'55AMG's Avatar
AMG
They also make a CM90 don't they? I would try that
Old 07-30-2012 | 05:28 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
There's a thread around here somewhere comparing the cm30, mez, and bosch '010 pump with the bosh '010 coming out on top.
Old 07-30-2012 | 07:08 AM
03'55AMG's Avatar
AMG
I think this is the post you were talking about Sterling E55
https://mbworld.org/forums/w211-amg/...g-results.html
Old 07-30-2012 | 08:56 AM
e55amgrocket's Avatar
Dirt Scooters
Meziere 100%. I had a problem with my heat exchanger and went from all kinds of setups and pumps and after putting a custom heat exchanger on and testing more I found a single pump in the rear with my trunk tank worked best. I would say the same would be true for having just that pump up front also. The best thing to do us add a trunk tank though honestly.
Old 07-30-2012 | 09:03 AM
chawkins2001's Avatar
2006 E55 AMG
I have two mezieres on my system, one in the back by the tank, and one upfront by the HE.
Old 07-30-2012 | 09:29 AM
amx1397's Avatar
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
Johnson CM90 pump is putting out 27 GPM @ 3 psi,= 0.1 bar
Description Part Num Fittings Voltage Flow Price
CM30P7-1 10-24503-03 or
10-24488-03 16mm
(5/8 in) 12V 5.2 g/m @ 0.1 bar $145
CM30P7-1 10-24504-03 or
10-24489-04 20mm
(3/4 in) 12V 6.9 g/m @ 0.1 bar $145
CM30P7-1 10-24504-04 20mm
(3/4 in) 24V 6.9 g/m @ 0.1 bar $145
CM90P7-1 10-24750-01 20mm
(3/4 in) 12V 17.2 g/m @ 0.1 bar $250
CM90P7-1 10-24750-02 20mm
(3/4 in) 24V 17.2 g/m @ 0.1 bar $250
CM90P7-1 10-24664-01 38mm
(1.5 in) 12V 30.4 g/m @ 0.1 bar $250
Infamous 1's Avatar
2004 E55 AMG
I am using the Bosch 010 and have no issues
Old 07-30-2012 | 09:56 AM
cij911's Avatar
one car at a time
The Bosch 010 has been shown (flow wise) to be the best plug and play pump....
Old 07-30-2012 | 10:00 AM
cij911's Avatar
one car at a time
What is wrong ? Not reliable - having to replace frequently ? Supercharger running hot ?
The Bosch 010 is better than the CM30, but I would not replace a working CM30 with a new Bosch 010 as you won't really see any gains.
Old 07-30-2012 | 01:32 PM
Forrest Gump 9's Avatar
shrimp boat
Meth injection?!
Quick Reply: What's the hot ticket in Intercooler pumps?
