Uhhh ohhhh...airmatic is giving me signs...
Old Aug 3, 2012 | 10:58 PM
GT-ER's Avatar
2005 E55 AMG
Today on my way to work my car was acting kinda funny, it felt "soggy" in the rear end. When I got to work everything looked okay. Once I got out I saw the horror....my driver's side rear end was on the floor.
I turned the car on, it came up and I drove it home. It felt normal too. 3 hours after getting home, the car is still fine.
Does anyone have any diagrams or any tips on diagnosing airmatic problems ( particularly leaks )?
Old Aug 3, 2012 | 11:13 PM
johnnyblaze's Avatar
CLS63S
If i leave my car alone for 5-6 hours the back end will tuck my rear tire, if I leave it in comfort mode. If I leave it in sport 1-2 it will stay the same height. My car has done this ever since I lowered it with STAR.
Old Aug 3, 2012 | 11:38 PM
GT-ER's Avatar
2005 E55 AMG
That weird. My car did this once before but it was both sides and it was after a few days of not using it. After I turned it on it went up and never gave me any problems ( this was almost a year ago ). This is the first time since then this happens and it was only on one side this time.
Nearly 4 hours later, car is still a-okay.
Old Aug 4, 2012 | 07:41 AM
GregMB's Avatar
Time to start accumulating coil over parts, I guess.....
Now that the conversion process is so well documented, it seems silly to fix the AirMatic system anymore.
I secretly hope that my AirMatic fails before 2016 so that my warranty company will finance the coil over swap!
-G
Old Aug 4, 2012 | 08:00 AM
GT-ER's Avatar
2005 E55 AMG
-G
I'm not sure I want to. I'm kinda in love with airmatic since my roads here are so screwed up and my car is one of the most comfortable cars I've ever driven with with the small tire sidewall and lowered suspension.
UPDATE: This morning my car was still okay. WTF? What could have happened?
Old Aug 4, 2012 | 08:28 AM
GregMB's Avatar
Well.... The good news then is that there should be a good supply of AirMatic "takeoff" parts available as people continue to do the coil over swaps.
Shouldn't be too hard to locate a used replacement part for whatever parts ends up being bad.
-G
Old Aug 4, 2012 | 08:36 AM
E55Dimon's Avatar
E63S
One of my neighbors has his daily driver E500 rear slammed on the ground most of the week. Going on 2nd year and says it drives fine, goes up etc. Looks pretty cool
Old Aug 4, 2012 | 08:41 AM
GT-ER's Avatar
2005 E55 AMG
I'm thinking about arnott's new rear bellows. Supposedly they are somewhat stiffer which I'm interested in.
But I have to know for sure that it's my rear bellow that is bad before I do anything.
Old Aug 4, 2012 | 09:33 AM
cij911's Avatar
one car at a time
Sounds like you have a small / slow leak....Sometimes the leak occurs at the fitting (where mine was leaking), other times the seals are shot....Soap & water solution is often used to find air leaks (look for the bubbles)....
I agree with you that for road cars, the air suspension is great...I love that I can raise my car, with a button, if I need to...
Old Aug 4, 2012 | 09:58 AM
GT-ER's Avatar
2005 E55 AMG
I thought so but why did my car drop in a few hours one day and not drop at all the next day? There has to be a leak but it must be variable. Perhaps the air purge valve is getting stuck open?
Old Aug 4, 2012 | 10:21 AM
cij911's Avatar
one car at a time
Sorry I misunderstood....if it only happened once, then yes it sounds like it may just be a valve that stuck open...
Old Aug 4, 2012 | 06:58 PM
GT-ER's Avatar
2005 E55 AMG
Can anyone tell me if this is a common problem?
Old Aug 5, 2012 | 02:11 PM
Shifter's Avatar
E55, SL63, ML550
Was there any significant temperature change the day it happened?
Old Aug 5, 2012 | 03:52 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Did you read the instruction on how to install his new Arnott's design bellows? The instruction is on their website. You have to drop the rear exhaust section and the rear end to install it. Fk that!
Old Aug 5, 2012 | 03:54 PM
Shifter's Avatar
E55, SL63, ML550
And what do you think you need to do to replace a factory unit??
Old Aug 5, 2012 | 04:22 PM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Hand the dealer the keys and bend over?
Old Aug 5, 2012 | 04:39 PM
Shifter's Avatar
E55, SL63, ML550
Haha good one
Old Aug 5, 2012 | 08:16 PM
GT-ER's Avatar
2005 E55 AMG
Loering the subframe is not required. You just have to disconnect the expansion tank, something mb doesn't recommend and thus why they recommend lowering the subframe. I think they are nuts.
Old Aug 5, 2012 | 08:21 PM
Hulk's Avatar
A Merc
^^^^^ yes my tech said the same thing and works every bit as good and waaaayyy less time to do the job
Old Aug 5, 2012 | 08:25 PM
Shifter's Avatar
E55, SL63, ML550
They say not to because the seal is critical and "cannot" be assured
Old Aug 5, 2012 | 09:12 PM
GT-ER's Avatar
2005 E55 AMG
Yep...although I'd rather try 10 times to seal it right before I'd lower the subframe.
Old Aug 6, 2012 | 05:51 AM
GT-ER's Avatar
2005 E55 AMG
Oh, and my car has yet to replicate the problem...wtf?
Old Aug 6, 2012 | 01:30 PM
AMG893's Avatar
2010 C63 Estate
Hopefully it was just a one off?
Old Aug 6, 2012 | 01:40 PM
justinwrock's Avatar
Ducati
coils!
Old Aug 6, 2012 | 04:40 PM
GT-ER's Avatar
2005 E55 AMG
Originally Posted by justinwrock
coils!
I would love to...but I'm afraid of losing my comfort.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
