w211 e63 subwoofer help
Old Aug 10, 2012 | 10:20 PM
lfe136's Avatar
2006 C230SS, 2007 e63, 2009 gl450, 2003 Ducati 749
About to rip out the factory sub and install a trunk set up. I have read through every thread and I am left with just two more questions.
1. The factory sub has two plugs, does this mean that the factory sub is a dual voice coil?
2. Does anyone know if the speak wires going to the factory sub is already a low pass or is it like all of the other speakers (both hi/low)??
Old Aug 10, 2012 | 10:50 PM
Roverron's Avatar
ML63
dual V/C yes
crossed over at sub feq yes
Old Aug 10, 2012 | 11:07 PM
lfe136's Avatar
@Roverron - So I am using a Fosgate PBR500x1 that has high level and low level inputs. Can I just tap into the factory sub speaker wires, for each coil, and go directly into the PBR500x1 or should I do it differently?
Originally Posted by Roverron
dual V/C yes
Old Aug 10, 2012 | 11:36 PM
bstudey01's Avatar
2003 E55 AMG
If you have high level inputs you should not need a converter. Although I used one anyway with my JL 1000/V2 just to be safe and plugged into the low level inputs
Old Aug 11, 2012 | 12:18 AM
lfe136's Avatar
Which speaker wires did you tap into for your signals?
Old Aug 11, 2012 | 12:24 AM
bstudey01's Avatar
2003 E55 AMG
I used both pairs of Subwoofer wires. I believe they were yellow and yellow/brown and can't remember the other colors, btw the striped wires are the negative, found a wiring diagram for car on this forum. If you pop of the cover in the rear window you will see both pairs of wires. I just clipped the connectors off and pulled them into the trunk. I'm using this converterhttp://www.ebay.com/itm/150853467089...84.m1439.l2649 and it works great.
Old Aug 11, 2012 | 08:48 AM
Roverron's Avatar
ML63
use a converter to be safe and thats all you have to do. you might want some kind of level adjustment up front
