Spark Plug Question
Tranmission and rear diff service should be done. make sure you change the eletrical connector on the transmission this will prevent the fluid from wicking up into your TCU over time.
Either way though, my plugs (ordered from Amazon) did not come pre-gapped and they were all in the .050 range.
I need to do this as well, as my plugs are original. Can you tell me the exact plugs you'd recommend based on my mods below? Also should I get new wires? Happy to buy them from a sponsor here as well. Have to support those that help me!
See sig for mods and for what it's worth, I live in AZ (Crazy hot right now), so any plugs that run, "Colder" are good I'm assuming?
Thank you in advance.
Alex
Alex
FYI, the temperature rating has nothing to do with ambient temperature.
Thanks.
Alex
