- Mercedes-Benz E-Class: Why won't my sunroof open
Guide to diagnose trouble and recommended solutions
Pano roof sunroof and sunshade problem
First, when opening the sunroof for it to travel back giving you an opening to the sky, does it stop in intervals? I don't remember it doing this before and it doesn't make sense to me that it should be. I have to let off the button and then hit it again like 4 times to get the sunroof all the way open and have no clue what would be causing it to do this.
Next and my main concern is the sunshade will not close. I used it the other day opening and closing the shade (left sunroof closed though) and it was fine. I often times always have the shade open but it has been hot as blazes and I want to close the shade but when I went to close it, it just makes grinding sound. I have tried opening all the way and holding the button in the open position and then reclosing, and it won't close the shade and makes the terrible noise.
It is like it doesn't know the roof is closed all the way and is trying to close it more and since it isn't closed (well it is but it thinks it isn't?) the shade won't start closing. Anyone ever experience this? I did some searching and found a few problems but they weren't what I am experiencing so not sure if I just haven't found a similar problem yet with my search terms or what.
It would be awesome if someone did know what was causing this because the sun beating down in to the car is starting to suck big time with it being hot as hell out right now.
Here is a video I took of the roof opening in intervals and then the grinding and sunshade not closing.
Was yours making the machine gun sound?
I hope this helps.
https://www.youtube.com/watch?v=z5F4uMxLYLM
I hope this helps.
Had a big scare when I was not able to get the sunroof to close all the way, and found a few bits of broken black plastic inside the aluminum rails, so I tightened the screws on the motor as tight as I could and after lots of pulling and prying on the glass I was able to get it to open and close again, but this time with the machine gunning every time I closed it fully. Decided not to F with it anymore, stuffed some foam in the tracks to stop/muffle the rattles, closed it one last time, and unplugged the motor before putting my overhead console back together.
After a #9 fuse pull I am still able to use the power sunshade, and this is fine with me because I never really open the actual sunroof but it's nice to have the view out sometimes. HOWEVER, the problem now is that if I open the sunshade all the way it will not close back until I do another fuse pull reset. If I only open it 99% of the way I can close it back no problem. I was wondering though, if there is a workaround for this? Perhaps coding out the sunroof motor so that the sunshade can do the one touch open one touch close without looking for the sunroof position at all? Or maybe even some kind of resistor hack? Any ideas? I'm okay with it the way it is, but it would be super nice if I could get at least the sunshade working as it is designed and not having a rattling pano roof is worth not having it open. Thanks!
Thinking I need to drop the headliner to access the motor and do the washer fix from YouTube.
Wish I had all the money in the world, I’d pay one of those RV windshield companies to make me one solid piece of glass to cover the whole roof and rip out all the opening and closing hardware of the pano roof and just have the sunshade.
The panoramic sunroof is not something I use often either but the sunshade is necessary during the Texas summer. Right now I'll just pull the fuse once again and not open it 100% as you've been doing it.
I'm trying to understand the mechanics of how pulling a fuse makes the motor work just fine for one cycle and then not work again.
My prior Brake Bleed tool I made from a HD Fertilizer/Pesticide 1 Gal unit I attached a Pressure Gauge to had a blown pump, so when I went to get another one, the opening was too small to fit a hand in to attach the Pressure Gauge, but I attached the same wand I used one the 1st, and it screwed on perfectly to pump Tranny Fluid. For those you wondering, I cut off the end of the HD wand and simply attached clear tubing to it secured with stay ties.
I then noticed I had a Hydraulic Oil Leak from one of 2 of my RMT ReBuilt Front Struts! I had taken my Driver Side in a few months ago when I began doing the replacement TCU. That one was covered by Warranty as I had brought it in more than once since 2017, but the other one had not, so the warranty had expired. Nonetheless, I still stand by RMT and their best efforts as a brand new one is $$$!
So while I was waiting for that, I busted out the replacement Brake Hoses I had stashed away. There was No better time than the present, so away I went, this time without trying to use the Brake Bleeder as my last effort proved to be a total mess! This time I just made sure to replace the Fluid at the reservoir every 5 pumps or so. In retrospect, I could have done 10 pumps, but I was being overly careful not to allow air into the system via the reservoir, a big “No No”. I still had that cacophony of sound when pressing the brake while bleeding the passenger rear (probably the Driver too but I was too far away to hear from the Caliper). I’ll add that I bled the Driver Rear 1st with a helper pumping the brakes just after replacing the hose. Yes, WIS calls for the Pass Side to “ideally” be bled 1st, then Dr R, Dr F, Pass Fr, in that order. After the Dr R, I ended up doing rest of the Hose Replacements/Bleeding by myself as WIS states that you should actually pump continuously making sure to draw the pedal back up slowly during the process so as to NOT introduce air. In order to get rid of that sound emanating from the ABS Rears, I going to have suck it up and bring it in provided Mercedes doesn’t tell me that they have to devote this many hours to confirm my connections are secure!
But I Digress, after completion of the above, I am now in process of “Alignment” since I made 2 turns inward (Increased Camber with negative angle) on my F1 Upper Front Camber Arms as my steering was straight but too light! By doing so, it will splay the front tires outward slightly, so the tie rods will have to adjusted (tightened) in order to tighten up the steering! I’m shooting for 1mm (2mm total).
That said, and since this is what the Thread is supposed to be about, when I pulled her out of the garage, The Sunroof was “Not Programmed” so I experienced being able to only open/close the Pano Roof Sunviser(s). WIS only states that the Switch must register the end point from the Hall Sensors at each stop. What this means is After reaching the end stop for the Visors, you have keep the switch depressed for a couple seconds (I counted 3) then return and do same, do again to open then push up to Tilt counting again to 3, then down to 3, Tilt Again and proceed to open all the way (here it may only open a couple inches at a time) then again the at the end continue to push the switch for 3 seconds, and return to close and do same. Then it should be fully programmed! It worked for me!
