Spacers for E63
Old Aug 15, 2012 | 08:36 PM
BMCINSD's Avatar
2007 E63
Spacers for E63
Hi guys,
I have my 07 E63 lowered by STAR to around 25.5" all around. I wanted to make the stock wheels look a little more flush. In researching I noticed that H&R made 5mm, 10mm, 12mm,.. What is the best spacer to bring the wheels out a little bit more front & rear. I've searched but can't seem to find an answer.
Old Aug 15, 2012 | 09:09 PM
desired_speeds's Avatar
2007 SL55 AMG
around 10-15mm front and rear would look pretty nice.
Old Aug 15, 2012 | 09:37 PM
Bramage's Avatar
F-250
EEKKKKK!!!
10mm maybe. 15mm would be hellaflush
In looking at your car, I would say:
8 - 10 Front (You have a little more wiggle room there)
5-10 Rear (As much as you can go before you rub)
Old Aug 15, 2012 | 10:02 PM
Hulk's Avatar
A Merc
I put new rims, 18/8.5 front and 18/9.5 rear and the fronts are not flush, I went to a tire place and told me even if I put a 5mm it would rub because I'm lowered so I guess I'm out of luck
Old Aug 16, 2012 | 08:38 AM
62not63's Avatar
E63
Becareful with the front offset. Your driver side fender will cut into the tire when you make a left turn into a drive way or parking lot. I end up replacing the fender cause it all bang up.
My front wheel is 20x8.5 35mm with 10mm spacer, 25.5" front fender lip to ground.
GL
Old Aug 16, 2012 | 10:14 AM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
I have 15mm on my rears and still need more spacing!
Old Aug 16, 2012 | 10:24 AM
pnoyworx's Avatar
10 E63, Sold -07 E63
So when you banged up your fenders you were running this setup or a more aggressive? If I got this right your are at ET25 in the front with those spacers?
I ask because I am now in the market for wheels and don't want to tear up my fenders. I did this whole research on my W204, was told it was safe to do such and such and go with such and such tires so it had rounder shoulders etc. I'm at 25.5 also on my W204, with a -.080 camber, ripped my finder slightly towards the front where the bumper and fender meet.
So I just want to double check where people are. I'm going for the same flush look, but I'll sacrifice the look to save my fenders.
GL
Old Aug 16, 2012 | 10:25 AM
djrabbi's Avatar
I dented my fender also for being too low but it still looks good
Old Aug 16, 2012 | 04:29 PM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
We currently have 5mm, 12mm and 15mm's in stock if your interested in stopping by.
Let me know our address is below.
Old Aug 16, 2012 | 04:36 PM
Vic55's Avatar
Administrator
you have a CLS not an E
