Manual way to disarm the immobiliser?
Hi guys,
So my car has decided to drain it's battery without ANY kind of indication again. Recently I changed the aux battery module under the hood for the small battery and all was well after that. I've not seen the convenience functions message in weeks and I'd driven my car everyday this week as normal (except friday) and it has been fine.
Today, I go to my car to meet up with friends aaaand nothing. So I'm like FML it's drained itself again!? So I get my other car, get to charging the E55 and after a few minutes I do the now routine procedure of turning the ignition to see if it'll start with a jumpstart.
As I got close to the inserting the key, a message popped up saying Key Not Recognised, but before my brain could process the message, I'd already put the key in and turned it. The car cranked once and immediately shut off completely. It now doesn't respond to any unlock/lock requests from my key (even when the battery is being charged by the other car and showing 14+ volts) and I can't turn the ignition at all - it just doesn't accept the key at all.
How bad is this situation? Am I at the mercy of a local cowboy with a star diagnostic tool, or is there something else I can do?
I'm really hoping that as it drains itself dry again this evening. by tomorrow when I go to jump start it, it should hopefully 'remember' (lol wishful thinking, I know) my key and fire up as normal...
Received 1,483 Likes
This place is a joke.
A dead battery won't cause your car to "forget" the key. If your battery is flat dead, even a jumpstart may not work. You may have to charge the battery or replace it.
Hi guys,
If you do not have the second key, does the red light blink in the key, every time you press lock/unlock. Sounds like you are having DAS issues, or as E55Greasemonkey mentioned your battery is completely flat.
Thanks guys, that's reassuring to know. Hopefully I just tried to start it too soon and the single crank just stone cold zapped whatever was left in the battery, eventhough it was being charged by the other car.
I'll give it a good 15 minute charge via my other car and then try to charge it again. Thanks guys, I'll keep you all posted. Team MBWorld FTW
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
If you have a vrla battery and it's fully discharged, put the charger on engine start mode for 15 minutes first. Then leave it on high for a hour, then let it trickle overnight. The vrla batteries for what ever reason, respond best to this method. It will never recharge with just a standard trickle if it was fully discharged. Just the nature of the gel vrla battery.
